Results 1 to 9 of 9
    last time nag-change oil ako, I bought shell helix super, instead of Shell helix DIESEL super. nagmamadali kasi ako non kaya di ko na masyado napansin. buti na lang, biglang may nakita akong sign board ng Shell helix diesel. Stop agad ako sa nearest shell station at bili na naman ng tamang engine oil.
    problem: pwede kaya yung Shell Helix Super sa diesel engine? i checked the rating and it's API CJ rated. CD 40 lang naman required ng makina ko. Kung di pwede, pwede kaya sa transmission ko na lang gamitin?
    hay nakow. sayang din ... pang exchange gift ko na lang kaya? :D
    Aug 2003
    i have used shell helix super many times on my 1999 frontier. it works very well with my 200k+ mileaged engine. i see no reason why it won't work that well with your rig too.
    rsnald,
    Yes Pwede ang Shell Helix Diese Super I;ve been using it on my 163 ok yan pare.... maganda ang hagod....
    sa 381 ko still need to use it pa....
    teka teka... medyo nagkalabuan...
    dalwa kasi yung Shell Helix Super,
    1. Shell Helix Super , 25W-40, API SJ/CJ rated. meaning both rated for gasoline and diesel (?), di ba CJ ratings are for diesel?
    2. Shell Helix Diesel Super -15W-40 rated, API CJ rated.
    Yung #2 ang ginamit ko. yung #1, tinago ko muna. Sabi sakin nung gasoline boy, pang gas engine lang daw yun.
    sumagot na rin yung Shell...
    eto sagot nila
    "----- Original Message -----
    Cc: Usison, Patricia R. PSPC-OCO/23
    Sent: Thursday, December 11, 2003 3:55 PM
    Subject: RE: Fw: Shell Helix super vs. helix super diesel
    Dear Ronald,
    Helix Super can also be used for AUV diesel engine because its rating is API SJ/CF.
    Please see attached technical info for your reference.
    Best regards
    DJ N. Javier
    Tech Sales Engr."
    pwede naman pala. at least di nasayang yung pinangbili ko.
    thanks na rin sa mga sumagot, master boknoy and diesoline.
    eto sagot nila
    Dear Ronald,
    Best regards
    DJ N. Javier
    Tech Sales Engr."
    kailangan ko nanaman helix super diesel due na naman ako for pms gastos na naman...........
    Pwedeng-pwede po sir rsnald ang Shell Helix Super sa diesels since rated API SJ/CF ang rating niya. Pero syempre mas OK Shell Helix Diesel Super dahil CF/SJ naman siya. Hmmm... parang binaliktad lang di ba...
    i remember when my pickup was they would use castrol i think same rating with the helix..ok lang yun sa oil na pang gas engine wag lang gasolina ang ikarga sa fuel tank..ehehe
    15Dec2003 (UTC -8)
    Engine oils marketed for gas engines, but have CF or similar specs meant for diesel engines, are OK to put on a diesel engine for emergency use. Remember, great oil is better than acceptable oil. Acceptable is better than dirty oil. Dirty is better than no oil.
    However, it will not do as good a job meant for diesel engines as there are not enough additives in it. Example, soot control is important for diesels, as well as resistance to acidity.
Shell Helix Super, pwede ba sa diesel?
