Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 55
    i met some guys in such practice up to 50:50 ratio.
    i dont want to try it myself.
    nope. and i wouldn't.
    ako rin!! diesel ang makina tapos hahaluan mo ng pang-luto..!!
    sabi din ng iba ok din un unleaded..
    di na noh..!! diesel nga makina ko eh..!*!
    this has been an issue dati pa sa old kotse board...and other boards....
    it aint good at all.....
    Kerosene with diesel is good for easing startups in winter.... which we dont have here :D
    mas mura ba kerosene kesa diesel?
    Signature
    Quote Originally Posted by boybi
    kerosene is cheaper.
    weird talaga yung practice nila but they are doing it for years.
    nalaman ko ito sa tanay, rizal. mas powerful daw kasi.
    the vehicles they use?
    reo 6x6 for hauling logs and the 6-cylinder passenger jeeps, 6FB1 ata engine. gray nga ang usok nila instead of black.
    some put ATF oil with every full tank of diesel. one quart of ATF for every full tank, it makes good power said some but never tried it.
  9. yebo8 Guest
    kerosene burns faster and cleaner than diesel. jeepney drivers do that when they get caught by the denr anti smoke belching drives. they mix kerosene with the diesel so that the engine will pass the test at the lto, less carbon monoxide and soot kasi. also since it burns faster than diesel it also gives higher power output.
    you can actually even mix kerosene with gasoline. in fact your gasoline engine can run on pure kerosene. start it up using gasoline then when it is already warmed up you can switch to pure kerosene (this means you have 2 fuel tanks, 1 for gasoline and 1 for kerosene). no guarantees it won't knock, though. here on the rig our rescue boat has 2 fuel tanks, one gasoline and 1 kerosene. parehas lang lakas ng acceleration nya pag naka-100% kerosene na e.
    aviation turbo is simply clean kerosene (low sulfur). as a matter of fact, the 2nd stage of the Saturn V rockets that took the Apollo missions to the moon used kerosene for fuel. that is how powerful kerosene is. they use it on 747 passenger planes, f15 fighter jets and even moon rockets, so why not your diesel engines! it is a lot cleaner than diesel mind you.
    the only draw back using pure kerosene on your diesel engine is you lose lubrication on your injection pumps (diesel is thicker than kerosene). but if it is mixed with diesel then ok pa yan.
    Great spirits have always encountered violent opposition from mediocre minds.
    --Albert Einstein
    so sino na sa inyo ang gagamit ng halo2?
have you tried mixing KEROSENE with your diesel fuel?
