Results 3,091 to 3,100 of 4200
February 2nd, 2009 09:08 PM #3091
Curious lang ako...so dun sa mga meron real-time fuel consumption meter (e.g. Fortuner), I guess it would be interesting to see the "mileage" you're getting on the display when running on LPG??
February 3rd, 2009 10:38 AM #3092
I have MID in Innova same with other IMV (Fortuner and Hi-Lux), the display is the same as it calculate base on the matrix of Air-fuel mix, electronic gas pedal movements, electronic throttle, cam/crank MRE sensor and emission sensors. Basically, it does not include in the matrix the gasoline tank meter as it will not give accurate reading all the time when the car is moving.
So when on LPG mode, the MID average Km/li reading is just as normal when in petrol. I usually get a minus 1-2 average Km/li reading when on LPG.
February 3rd, 2009 04:11 PM #3093
February 3rd, 2009 06:43 PM #3094
It won't be accurate. It's guesstimating based on injector duty cycles (based on the ecu signals sent to the injectors, not based on whether the injectors are working or not), and as the air-fuel ratios are different on LPG, and the LPG injectors are "trimmed" to a different calibration than the gas (even with the same AFR based on O2, since stoich is different for LPG and gasoline), it'll always be a little off.
- Jul 2008
- 102
February 4th, 2009 03:33 AM #3095hi smdelfin! actually the shortage is not because of hording etc. its because of Europe buying LPG now that its winter time. LPG is a by-product when you produce gasoline and diesel so i don't see it having shortage issues due to production and its prices should return to normal levels soon enough.
February 4th, 2009 10:47 AM #3096
- Aug 2008
- 3
February 5th, 2009 08:21 PM #3097Good evening to all auto lpg users. I have been using it for 5 moths now.
My friend said this morning that there was a news of a taxi in makati whose lpg tank blew. Please shed light on this matter. Thanks
- Aug 2008
- 3
February 5th, 2009 08:25 PM #3098good evening. Please shed light on what caused the taxi in makati that is running in lpg that blew up as per bomboradyo report last feb. 2. TY
February 5th, 2009 10:54 PM #3099
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
