Results 41 to 50 of 59
- Nov 2009
- 3,509
April 16th, 2014 11:44 PM #41Tactic No. 2: Avoid Slowly Crawling Up to Speed
Conventional wisdom says that jackrabbit starts consume more fuel. But it turns out that nursing your speed up to the limit too slowly also lowers mpg. How can that be? Cars get poorer fuel economy in lower gears, and accelerating too slowly prevents up-shifting at an efficient rate. The best acceleration rate varies with the vehicle, gear ratios and weight. But in our testing we found that taking 15 seconds to accelerate to 50 mph used less fuel than taking 30 seconds to reach the same speed, because the car entered its top, fuel-saving gear sooner.
Here's a simple test how to get better econmy using the right gears.
UD Trucks Quester - Fuel efficiency training
- Aug 2014
- 29
- Jan 2015
- 14
- Apr 2015
- 6
October 19th, 2015 11:57 AM #46
Ano po maganda for personal use car? Gasoline or Diesel engine? Yung makakatipid ako in the long run. Lets say 10 years. Thanks po
- Aug 2015
- 862
October 19th, 2015 01:47 PM #47^^ano ba usual route mo sir. Kung mejo regular ka sa malayuan diesel siguro.
- May 2016
- 6
May 6th, 2016 01:48 PM #48You maybe tempted to skimp on visits to the mechanic and use the money to pay for gas
instead, but getting a tune-up and replacing air and fuel filters at
recommended intervals will help improve engine efficiency and boost mileage.
- Jun 2016
- 3
- Aug 2016
- 8
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
