[SIZE=2][SIZE=4]How does it work?[/SIZE][/SIZE]
[SIZE=2]Ans. [SIZE=4]SPEED PLUS Mileage Enhancer[/SIZE] is a catalytic converter uses the elements in the air to fine tune the fuel & air mixture entering the intake manifold to the chemically correct (stoichiometric) ratio (14.6 parts air to 1 part gas). Moreover it distributes this mixture uniformly to all the cylenders of the engine. And recycles the unburned carbons into usable gasses thus giving a higher fuel yield. During burst of acceleration and deceleration SPEED PLUS chemically adjusts & help supply exactly the right fuel and air mixture (lean or rich) at the right time so that the engine can run powerfully, economically and without the air pollutants that results from poorly mixed, distributed and burned fuel.[/SIZE]
