Results 1 to 13 of 13
    Feb 2014
    suppose you need to tow a small atv that's around 300kg. plus 100kg for the trailer.
    suppose we exclude pickup platform vehicles and cap the budget at 1.5M so that excludes subarus
    exclude CVT coz towing will kill the cvt (unless it's a subaru)
    what options are we left with???
    Quote Originally Posted by Vodka View Post
    A good used v6 120. Uber reliable....Plus, you get back a chunk of change to spend on petrol.[emoji4]
    Sent from my SM-S901E using Tsikot Forums mobile app
    Sep 2004
    Kahit bigbody corolla with manual tranny kaya yan kahit unbraked pa yung trailer. kung may preno yung trailer instant madoble capacity.
    kahit anung bagong oto siguro ngayon with at least 140NM of torque tas manual tranny kaya yan.
    Feb 2014
    Quote Originally Posted by L1quid View Post
    forgot to add... "automatic" dapat
    m/t options are plentiful. even a cheap toyota liteace panel could already hold 700+kg INSIDE the car, could definitely tow a lot more
    Jul 2013
    hmmm. brand new ba dapat?
    I think the Jimny can handle your requirement
    Feb 2014
    yes bnew dapat. yeah jimny could do it w/ the 1.3 ton capacity which is kinda crazy coz 1.3 is already heavier than the car itself
    what other options do we have?
    Jun 2011
    Innova E sana kaso PPV. Puwede din Rush, Xpander, Territory, Stonic, Tuscon gas. Kaso di yata malagayan tow hook ang unibody?
    i'd google, "what is a good tow vehicle?", see the specs, and see what's available locally, that suits my fancy.
    Jul 2013
    hmmm. requirements.
    NOT pick-up based
    Automatic (not CVT)
    1.5M budget
    Brand New
    I was initially looking at Tata and Mahindra... but their models are mostly manual
    Feb 2014
    Quote Originally Posted by bxr monkey View Post
    i googled xpander towing capacity. quite a few south african sites are quoting 550kg! interesting. meron din talagang advantage ang 4spd a/t
    pwede kabitan ang unibody. you just need some thick metal inserts INSIDE the frame rail so you don't rip the hole out. these "rails" are made from thin stamped steel
    diesel na accent/tucson maybe?
    May 2016
    Perfect suggestion yung Innova. I wonder why no PPV suggestions, many Tata and Mahindra are also based on ladder frames afaik.
    Otherwise any crossover with a slushbox AT would do fine. Tucson gas pasok sa 1.5M. CX-5 2.0 can probably be had with hefty discounts to come close to your 1.5M budget.
    I wouldn't trust a 1.5 subcompact like Xpander or Rush to haul 400 kilos, those things only weigh around 1.2 tons.
    hmmm. requirements.
    NOT pick-up based
    Automatic (not CVT)
    1.5M budget
    Brand New
Tow vehicle that's not a PPV for 1.5M...
