Results 91 to 100 of 129
April 1st, 2007 12:19 PM #91
Tsikot Member Rank 4
- Jan 2007
- 2,326
April 1st, 2007 03:19 PM #92It was my theory na a big part of ATs popularity is not really just convenience but the unwillingness of a large part of new drivers to learn MT. Pati mga utol ko ganito eh.
Hehe. Dapat ata sa mga new AT drivers paakyatin ng Baguio behind a slow moving long truck para matutunan din nila mag MT. hehe.
- May 2007
- 18
May 19th, 2007 09:58 AM #93ABOUT CVTs.
What about CVT on uphill driving? may chance rin ba na mag-stall yung engine? what about when you come to a stop while on an uphill traffic? do you need too 'manually' shift(+/-) gears?
sorry, newbie lng po
May 19th, 2007 01:07 PM #94
my wife's city 1.3 cvt is what you call a manumatic, you can drive using the full automatic wherein the car does the shifting for you or you press a button for you to use the paddle shifters to experience the 7speed manual shifting (+/-).
once you are in full stop and in full automatic mode and you are going uphill, depends really how uphill, but it is advisable to put your stick to D1 or Drive Low, the car will do the shifting for you, if its not that steep, you can maintain in D3 or Drive high, the car will still go up and shift gears for you automatically. to use the manual shifter you have to engage the car's manual mode. once in full stop, for the honda city, the gear will be on the 2nd gear, you can now step on the gas and upshift manually (+) like you do a manual car (just without clutch) to 3rd, 4th and so on. the beauty of the system is, lets say you are running at 80kph at 5th or 6th gear/speed and you have to slow down by braking and by doing so your speed goes down to 30kph. you will see in the indicator that the gears/speed are automatically downshifting (-) for you, at 30 kph it may well be at around the 3rd gear/speed.
so to answer your question, yes you have to manually upshift (+) going uphill from full stop if you are in manual mode. you dont have to manually shift if you are in full auto mode (you just have to pick the right drive setting (d1,d2 etc) and the car does it for you. hope this helps.
- May 2007
- 18
May 19th, 2007 02:28 PM #95the beauty of the system is, lets say you are running at 80kph at 5th or 6th gear/speed and you have to slow down by braking and by doing so your speed goes down to 30kph. you will see in the indicator that the gears/speed are automatically downshifting (-) for you, at 30 kph it may well be at around the 3rd gear/speed.
May 21st, 2007 07:41 AM #96
the gears downshifting automatically is in manual mode. for the 2nd query, i think even none cvts have atleast three drive modes d1=low, d2=mid and d3=high. my dad's accord (2000 model/non-cvt) has up to d4. so on ordinary driving, we usually use d3, on highway we use d4.
for my wife's city (up to d3), we use d2 for city driving (stop and go situations) and d3 for highway. really really seldomly use the d1.
- Jan 2007
- 2,326
May 21st, 2007 11:06 PM #97Akala ko D1 means 1st gear, D2 2nd gear?, etc? Hindi ba? I thought kasi kaya siya nilalagay into D1 or D2 going down from baguio -- to engine brake?
May 26th, 2007 07:41 PM #99
Dati MANUAL choice ko... Ngaun AT na choice ko.... Medyo tamad na ako drive ng MT e....
- May 2007
- 13
May 26th, 2007 08:03 PM #100
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
