Results 1 to 13 of 13
    Worst 7 Seater SUVs | Auto Expert John Cadogan | Australia - YouTube
    You have to watch the whole video...
    It includes suvs sold in our market....
    Apr 2014
    Very colorful with words.
    Buti pa sa kanila highly regarded ang hyundai/kia dealerships.
    Sent from my Z410 using Tsikot Forums mobile app
    Nov 2014
    +1000 on the colorful language comment hahaha
    "Deplorable engineering, disgrace of a transmission" in the Ford Focus, Fiesta and Ecosport-- guy doesn't mince words (these three cars aren't even on his list, just mentioned in passing)
    Two of those on his list are described as the two heads of Cerberus guarding the gates of hell, a factory is called "what food becomes after it has been fully digested"...
    9/10 would watch again
    I like being direct to the point. I got bored halfway on the first SUV. So, I just moved the video slider to see each featured clunker.
    Gee. I kinda liked Nissan's new Pathfinder. I guess I'm taking it out of consideration as a replacement for my Sonata.
    Quote Originally Posted by chronicle View Post
    well kia philippines is ok. they allowed me to bring my own oil and filters, remove items in the job order that i can diy (e.g., brake cleaning), etc. it is hyundai h.a.r.i. dealerships that milks its customers to the max. price na lang ng spare parts layo na ng difference nilang dalawa.
    Sep 2014
    So ano suv's ditto an mention ayaw mag-play ng video
    Jul 2016
    Chevrolet captiva.
    Sent from my LG-H818 using Tapatalk
    fiat freemont
    ford territory
    chevrolet/holden captiva
    infinity qx80
    mercedes benz gl
    nissan pathfinder
    ssangyong rexton
    Jul 2013
    O.T. re: brake cleaning.
    Do you follow specific steps for this especially for ABS-equipped cars?
    Compressed air or brake cleaner?
    What type of grease is recommended for the brake pads? Is it necessary?
    I've been DIYing our Innova since 15,000km (change oil, change filters, etc) but I have yet to clean the brakes.
    Quote Originally Posted by Lew_Alcindor View Post
    make sure the hand brake is not engaged (unless the hand brake is a drum-in-disc affair). if possible pry the brake pads from the disc with a screw driver. i use either brake cleaner or crc. in fact even a high pressure washer can clean the brake pads. remember the objective is to clean the pads and not the disc so anything that will remove brake dust from in between the brake pad slots will work. it is the brake dust that accumulate in those slots that will lessen the braking power.
    the abs sensor is inside the assembly so it is not a worry.
    grease? why would you put grease on brake pads e di mababawasan ang braking power nun.
    di ba innova is drum brake sa likod? you'll need to remove the wheel and open the drum to be able to clean that. make sure you have a proper vehicle stand, safer kesa pag jack lang gamit mo.
    Sep 2012
    Brake pad disc nilalagay lang sa likod ng pad para hindi umingay... konti lang nilalagay dun and make sure walang sobra sa sides.
    Pwede rin naman hindi mo lagyan
    Sent from my Asus ZenFone 2 using Tapatalk
    Quote Originally Posted by jodski View Post
    sa likod as in between piston and pad? yun pwede pati na sa pins. silicon grease, very thin lang. ot na.
    Aug 2016
    This really helped thanks.
Worst 7seat SUVS...
