Results 1 to 4 of 4
    bros can u put quick inputs tnks
    Pros and Cons of Carburator type engine (1.3) vs Fuel Injected type (1.6)
    Carburator - Simple, you may be able to fix yourself.
    Fuel Injected - Everything else.
    Aug 2004
    From experience with a 1.3 Carb - yeah, it's simple to fix. I used to maintain my carb myself.
    But a 1.6 EFI will give you similar fuel economy (the 1.3 is better on the highway, but only if it's clean), less headache, more power, etcetera, etcetera, etcetera... but that's given that you keep it well-maintained and have the sensors cleaned every now and then.
  4. #4
    on a un-controlled/sudden car spin, tatapon ang fuel sa carb, ganito ang nangyari sa akin sa edsa using my maxima, noon nasilaw ako sa ilaw noong ginagawa pa ang MRT na yun.. sa malapit sa pasong tamo flyover. papaunta akong alay-lakad kasi sa ROTC na yan!2am...
    pero nga madaling ayusin ang carb than EFI system..pero mas matipid ang EFI system-->explanation:
    pour water sa glass mo using a pitcher-->carb
    pour water sa glass mo using hose-->efi...
Pros and Cons:Carburator vs Fuel injected
