Results 1 to 11 of 11
    Nov 2006
    mga bro ask lang sana ako oppinion niyo. I'm planning to build a semi project car which I can use for a little bit of racing at the same time daily use din, I'm considering the charade with 4efte turbo engine, or a corolla small body with 4efte turbo engine also, or a civic ef with d15b engine, kaya lang medyo mas tipid sa budget mas pabor sakin, ano po tingin niyo mga sir which car to build is better and yung mas mabibigay ang satisfaction ko? thanks and more power
    Kung racing lang talaga ef na!
    pag nilagyan mo ng b16a yan stock palang 14's na!
    Mar 2003
    ang mahal naman ng b16a and ang ef hatch nasa 140-160k parin ang bentahan. i'd go with the corolla mas maraming engine choices and much cheaper.
    Quote Originally Posted by igiboy07 View Post
    The charade with the 4efte engine would give you a good low cost drag car but your options would be limited after that. The corolla would give you better options in terms of engine choices and other tweaks like suspension, etc. but it would weight more and would result in slightly slower performance (against the charade with the same engine).
    EF with JDM D15b 130hp
    Oct 2004
    corolla mas matipid, the ef hatch kasi medyo de ganun karami parts compared sa eg hatch and the b16a is not a straight swap on an ef may igagalaw kapa alam ko so its nt as easy as an eg hatch
    go for the rolla
    Nov 2006
    thanks mga sir.. one more sa tingin niyo how much would be d cheapest corolla small body i can get yung stock lang? thanks.
Charade or corolla small body or civic ef
