Results 1 to 20 of 22
    Guys given a 1.8M budget which SUV or MPV would you would you suggest?
    has to be around 7 seats and roomy
    has to be powerfull ung malakas hatak
    has to ride comfortable
    and definetly dapat maporma!
    tnx
    sta-fe lang ok na sakin
    Jun 2003
    kia carnival may sukli ka pa
    May 2007
    Acura MDX nalang at matipid pa sa gas.
    Quote Originally Posted by v6dreamer View Post
    That's not available here in the Philippines...
    Santa Fe
    __________________
    bigbigcar.com Review: Mercedes-Benz C200 Kompressor Avantgarde
    i would go for diesel fed engines (CRDi) because of the rising cost of fuel which i see na, it will not go down to pre Php 38.00/liter levels.
    My choices:
    Sta Fe, Kia Carnival, Kia Carens
    may sobra ka pa.
    hhmm... mukang ok santa fe ah!
    ask ko lang guys anu diff. ng 4x4 and 4x2 na santa fe?
    well ofcors one is 4 wheel dirve and the other is not!
    what i mean is may diff. ba ride or sa hatak?
    tnx nga pala sa mga suggestions!
    Aug 2007
    Roomy enough for 7 full-sized passengers (not kids or midgets), I'd say Kia Carnival LWB.
    Quote Originally Posted by Mamar View Post
    ung 4x4 po na crdi dual airbag. ung 4x2 po driver side lang.
    Well, the 4x4 is heavier so you'll get a bit less performance from the engine from mid to high range.
    However, it'll make the ride a bit better AND will allow you to take off faster since mawawala ang wheel spin. Also, it's good for dirt/slippery roads as a safety feature.
    Pero experience ko po ito sa FXT ko ... hindi ko pa nata try ang SF AWD eh.
    I suggest you test drive po so you'll feel the difference.
    Mar 2007
    ford everest
    Nov 2007
    Sa budget na yan, I'd go for top of the line Kia Carnival, the one with captain seats and automatic opening/closing of side sliding doors and tailgate. SantaFe, of course, will also do
    I'd take the Ford Everest 4x2 A/T, tapos bibili ako ng Getz sa sukli dun sa 1.8M.
which SUV or MPV would you suggest with 1.8m Budget
