Results 1 to 18 of 18
    May 2010
    Hi peeps. First timer ako dito sa site. I'm planning to buy my first car. I'm choosing between mitsubishi lancer glxi pizza pie & honda esi. Factors that i'm considering are fuel efficiency, maintenance cost, & durability (ano ba mas matibay with regards sa kalawang)
    Thanks sa mga inputs niyo. =)
    ESi. It's an easy to mod vehicle and it's small.
    Hirap lang sa ESi eh yung kalawang issues which up to now eh di pa alam cause.
    Dami kalampag issues ng Itlog.
    ** Hmmm ... pansin ko lang. Bigla yata boost up yung ranking ng itlog sa mga choices ng mga buyers. hehe
    Aug 2008
    pizza na!
    ang issue lang naman sa pizza is the suspension daw. though, di ko pa nararanasan yun sa pizza ko kahit 13 y/o na.
    Aug 2008
    pizza na!
    Aug 2008
    pizza na!
    Aug 2008
    pizza na!
    Aug 2008
    sorry multiple post
    bakit di isali ang corolla?
    Apr 2009
    Both have all-power features and 1600 efi engines.
    But the GLXi has more torque for city drives.
    Both look good and are durable.
    They have readily available JDM aftermarket bolt-ons.
    Both have good suspensions.
    But the ESi's double wishbone set-up is a big winner in its class (Porsche uses a similar set-up). I never had problems with my ESi's suspension despite driving it hard (most of the time) and aggressively even on sharp curves.
    Rust?
    Both are old cars. Expect rust. ESi's are older and would most likely have them at the roof and rear pillars but who cares? Just have it washed over then you're good.
    I go for the ESi simply because it's got great suspension and more tuning potential (strong jdm engines bolt straight on).
    I heard it's not that simple swapping in jdm tuner engines in the pizza.
    If you're the go-racer type, get the ESi. Otherwise, the Lancer will be a good choice because of cheaper parts and lower resale value, which means you can get one for a lesser price.
    Jan 2009
    Ba't napunta ang itlog dito, hehe..? Pizza at ESi ang pinag-uusapan. 17 years na ang itlog ko wala namang kalampag. Samantalang ang 1999 Toyota Corolla XE (makinis at makinang) ng agency namin, dinaan sa rough road lumabas lahat ng kalampag. Mabuti pa ang tricycle walang kalampag, bumpy lang. Palitan pa ng bagong part ang lahat ng sira ng Pizza plus its price di pa rin aabot sa price ng ESi.
    Sareehh. :rofl:
    Nagkamali ako ng basa. :hysterical:
    Pizza pie pala.
    Pero, nonetheless makalampag pa din iyan. :bwahaha:
    Yung 96 corolla ko dinaan ko din sa very rough road, wala din kalampag. Hmmm ....
    Yung isa naman `00 1.6GLi from manila dinala sa Cebu ... by road.
    No kalampag issues din.
    May 2010
    Thanks sa mga inputs nyo. I've heard that ESI are prone to overheating, is it true? If yes, how can this be corrected?
    Apr 2009
    Quote Originally Posted by Briggs View Post
    Yes. Just have the thermostat replaced, water pump checked, radiator overhauled, aux fan motor upgraded and radiator cap replaced with 1.1 psi rating. Man just do this and you don't even have to convert the rad into two rows like most Civic people do.
    Then you can redline like hell (8500 rpm if you're lucky) and you need not worry about blowing gaskets...
    Aug 2009
    i had my esi also..im not bias coz im owning one..before i bought my esi,i have this kind of undecided decision wheather to choose honda,mitsubishi or toyota..but i ended up choosing honda,ganda ksi ng esi if my plan kang e upgrade yung exterior looks. sporty looks at easy to maneouever..ika nga small but handy..regarding the issue for the esi,it depends on how you maintain your car and how the way you handle your car. But still the decision is yours my friend. goodluck and hope for the best.
    Apr 2009
    Get the Pizza. Ipaayos mo nalang yung suspensions, voila. Mas makakatipid ka pa rin sa presyo.
    Apr 2009
    Actually, I basically had both cars. Get the ESi. Best choice.
    Dec 2008
    Hello po!
    How much na po ba ang price ng ESi 95 manual? compare sa GLXi 97?
    Thanks!
    Apr 2009
    Quote Originally Posted by veyron_27 View Post
    Hello po!
    Thanks!
    Ang alam ko po nasa 140K to 170K yung ESi M/T, depende sa kondisyon pero karamihan niyan stock pa.
honda esi or mitsubishi lancer glxi?
