Results 1 to 5 of 5
    Sep 2011
    mga sir na expert dyan, baka may ma advice kayo sa akin, pizza pie ko
    almost a year ko nang pinagagawa,pero ganun pa rin, kapag mabagal ung takbo nya parang kinakapos cya
    hindi ko lang maintindihan kung sa gas o sa kuryente, napalitaN ko na ang, sparkplug, tension wire,fuel filter
    timing belt, servo, fuel pump napababa ko na din ang tranny nya, pero ganun pa rin. neeeed help.
    what do you mean, kinakapos? palyado ba? nangangabayo? namamatay? walang hatak? please elaborate.
    Sep 2011
    minsan parang hinahapo, minsan kapag biglang tigil namamatay, lalo na kung bukas ang aircon, kung matulin ang takbo ok cya,
    kapag mabagal na biglang bigla parang nawawalan ng supply ng gas, kaya napapakadyot
    Better replace the ignition coil. I have a 97 Lancer as my 2nd car. For years I have to deal with the same problem, Citimotors discovered it and replaced the busted coil
    Not quite sure if this is the exact part, but it surely look like this
    http://daytonagblimited.co.uk/91-153...l-pack-626.jpg
    Don't forget to replace the oil seal because once the distributor is opened the oil seal cracks and oil will leak down to the wirings below
97 lancer glxi pizza pie
