Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Aug 2016
    Planning to venture van for rent business and for travelling as well. Torn between these two. I want feedbacks from those na may 1st hand experience talaga sa dalawa para mas thorough yung comparison.
    Engine
    Tranny
    Ride
    Comfort
    Maintenance
    Value for money
    Longevity
    Sent from my ALP-L29 using Tapatalk
    Quote Originally Posted by miguel20 View Post
    Engine
    Tranny
    Ride
    Comfort
    Maintenance
    Value for money
    Longevity
    See this. https://www.*****************/cars/c...van+premium-mt
    Engine - better performance for Nissan imho
    Tranny - same lang
    Ride - Nissan is more comfortable
    Comfort - Nissan, aside sa ride, their aircon is better than toyota.
    Maintenance - same lang yan
    Value for money - higher resale value for Toyota gives it an edge
    Longevity - same if you maintain it the same way.
    Based sa info na naririnig ko sa mga kaibigan ko at kakilala na nasa tourist transport service. Yang dalawang yan ang in-demand eh. Pero mas marami bumibili Toyota grandia vs Nissan.
    LSB posted a while back about how the Hiace Grandia could use a 5th gear. Umiiyak na daw yung engine at cruising speed.
    They upgraded the engine to the more powerful, new (to the Hiace) 3.0 but the tranny is still the same old 4AT. So if you do a lot of highway Km, something to consider.
    Yung NV350 Premium naman limited access pag lower than 2.3m yung indoor parking. Yung seats in stock form masikip yung 2nd row legroom. Much better yung seating ng "S" variant. Which one is better depends on your target clients I guess.
    Jul 2016
    I dont have both pero nasakyan ko na sila dalawa, mas maingay engine ng nissan compared sa toyota, sa comfort di ko masabi kasi sa harap ako naka upo sa nissan while sa toyota nasa rear passenger ako.
    Sent from my vivo 1606 using Tapatalk
    Depende Sa Usage, kung most of the time ba is more on travel?, at full load?, less load and least load?..
    + yung pahinga ng sasakyan, lalo sa engine at electrical lalo sa aircon, wear and tear sa brakes, gulong at suspension.
    kung long drive at excessive idling...
    After from point a to b, pahinga (rest period). then point c,
    + yung factor pa na merong papasalyan na within the area, uphill road condition,
    kasi once na namasyal, additional load factor dahil sa mga pasalubong na bibilhin..
    Aug 2016
    Pa advise naman. For commercial use sa rentals na urvan premium. MT o AT?
    Jul 2016
    Pag commercia use manual dapat
    by virtue of its design, MT is more robust, needs less maintenance, is more forgiving of maltreatment from busabos na drivers, and will generally last longer, than the AT.
    compared to AT, it will also lessen the fuel bill a bit.
    but...
    if you are the the driver, you will like to drive the AT more. it will also diminish left shoe wear.
    Nov 2017
    UP mga sir.
    Planning to buy either of the two. kaya kailangan pag-aralan.
    Salamat.
    Aug 2010
    Quote Originally Posted by krono View Post
    UP mga sir.
    Salamat.
    Mapili sa parking yung nissan nv350.
    karamihan ng malls sa metro manila hindi kasya sa parking yung nv350 premium.
    if hindi issue sayo yan. go for nissan.
NV350 Premium vs GL Grandia
