hi guys! i'm just a newbie here and i'm planning to buy a ride dis coming june, can u help me in comparing this 2 rides....
when it comes to maintainance b mahal tlga ang ford?
i already heard a lot of complaints kc pgdating s xwind eh.....
It's the new Everest... the Crosswind can't even compare by a bit to it.
The ride is good enough for our not-so-perfect roads and the acceleration of the 2.5L engine is very good (as compared to the old Everest).
Regarding maintenance, it's almost the same for them. There's a few problems plaguing some Everests & Crosswinds but nothing major that I've read so far.
sir, go for the Everest. Do not be easily intimidated with the sportivo's gadgets, unless you are into fuel economy its a go for you.
iam3739.com
mdmi nga po ngssbi n over price daw ang sportivo pero 2 think n mga gadgets lng nmn yata pngkaiba nya s XUVi.....
kya medyo nhhirapan ako mgdecide wether the XUVi or eve 4x2 M/T kz mdmi dn ngssbi n mahal daw ang maintainance ng ford... is it true po b?![]()
crdi over non-crdi. all new everest na even the 4X2 m/t.
xuvi is not an suv that could be compared to everest. it's everest
over crosswind even if sportivo pa yan. all new pa.![]()
Mahal ang maintenance? I own both a Ford and an Isuzu... and when it comes to maintenance at the dealership, I'd say there's not much difference.
For the first 30,000-50,000 kilometers, you should go to the dealership for regular maintenance, so as not to cause any warranty problems.
The only thing going for the Sportivo against the Everest is the OHV timing gear equipped non-CRDi engine. It's a very simple engine, which won't be as sensitive to diesel quality. And it's quite fuel efficient.
The new Everest, though, isn't as big a fuel-guzzler as the old one. It's very powerful, even in 2.5 form, and is probably too fast for its tires and height. It rides better than the Sportivo, it handles and BRAKES better than the Sportivo, and it has much much more space.
If you buy a Crosswind, the best deal is the base model, or the next one up, with power-windows. Even fully-loaded, in XUV or Sportivo trim, it's not really very luxurious, due to the choppy, rolling ride and the crude engine. Trust me... I drive one.
Mostly the same... the 4x4 is two tone, but the 2.5 is single color. There's a sort of titanium blue, black, gold and silver. Not sure about the rest.
Mga bossing, newbie here, pasensya na, di ko mahanap ang "introductions forum", so pa join na lang po. Almost made up my mind to go for the 2.5 everest. 2 nights na nga akong napupuyat kababasa ng forums.
My question:
What's better? the 2.5 everest AT or the manual? Pros & cons please.
Ayaw nyong magreconsider? Autofocus People's Choice AUV of the Year ang Crosswind!![]()
I'd normally say MT, but I didn't gel well with the stick of the Everest MT. And while cars with electronic throttles usually feel less sluggish with MT, there's still some response delay with the Everest MT, so I'd say the AT is the way to go with this one.
Maybe I'm just sour-graping because the Everest's electronic throttle wouldn't let me burn rubber during the test-drive's acceleration segment, shutting the engine down when I tried to slip the clutch. :hysterical: But if the computer won't let you modulate power delivery with the clutch and throttle, what good is a manual?
if you buy a diesel car today buy car with crdi engine,powerful,refine and efficient...
CRDi is generally smoother, quieter, higher-revving and more fuel-efficient.
There's still some worry about the long term effects of "dirty" diesel on CRDi injectors, but if you live in and around the city, and fill only at new and botique-style (big name, big space) gas stations, you should have no problems.
