Store#2 mas ok daw yung 1 amp V12 na 4Chn 4k Watts (new model daw)
mas ok daw yun crisp ng sound. (P 4,600)
Tapos parehas sila nag sasabi ng mga techi stuff na hindi ko naman maiintindihan . Ang isang hindi ko pa ma gets bakit hindi sila nag recommend ng 5Chn na amp na same spec nung akin dati Mga bossing pangit po ba ang 5Chn amp?
Bali yung speakers ko nga pala (Di ko alam yung technical details)
12" Aura Sub x 1
Pioneer x 2 Speaker (yung sa likod nakalagay - stock ata nung head unit)
Tweeter x 2 (Front)
6" DLS Sub x 2 (Front) (seps ata tawag dito)
6" DLS Speakers x 2 (Front)
use separate amp for diff config of speaker... and it depends on your budget... for me, use diff amp for sub and you can use 4channels for your speaker.. dont use 1 because it may cost alot and make sure your speaker is not under power... but between the 1st choice between 2 channels amp and 4 channels amp i would go 4 channel since m using 4speaker... nkatipid pa ako ang pera... and isa pa binigay nila 2amp 2channels kasi un lang stock nila... geezzzz
and lastly, its better to use separate amp for your sub... kasi mahal un 5channel and risky for underpowered... ma damay pa nakakabit ng amp...
1amp 4channel
for 4 speaker mas maganda 2way separate yun speaker and tweeter
1amp mono
atleast 10"sub
and head unit mo... dapat maganda din yun para hindi parang lata un music mo..hehehe
mga bro tip ko lang kung V12 ang hanap mo, sa V12 mrv f710 ka na . kc mrami nagsasabi sakin na yun daw ang pinaka malakas na V12 lalo na pag naka bridge, 4channel din siya and dual fuse siya 80 ampere bawat isa mura lang to sa raon P3,700 lang.
kaya niyang i-drive ang (2) 12"Pioneer TSW307D4 sa channel 1 & 2 ng naka bridge type at naka series connection ang dalawang sub's m at sa channel 3 & 4 ikaw n bahala maglagay ng 3 way mo,at para mas maganda at di hirap ang alternator mo mag add ka ng 2 farad capacitor at isa pa madadagdagan ng 10-20% na lakas ang sound mo tip ko lang po dahil nasubukan ko na mag setup ng ganito.
and kung gusto mo mag canvas para sa budget mo click mo lang tong link sa baba
nandito na lahat ng kaylangan mo
enjoy http://www.google.com.ph/imgres?imgu...26tbs%3Disch:1
Sa existing set up mo ngayon mas maganda kung may seperate amp ka para sa subwoofer mo at another amp para sa seperate speaker mo para hindi masyadong hirap ang amplifier at konting volume lang malakas na ang tunog.
