Results 1 to 5 of 5
    Aug 2011
    Guys, may nagbigay sakin ng amp na toh, newbie lang ako sa sound set
    Specs:
    Advanced Instrumentation Input Stage
    TC-X Crossover 12dB/Octave; HP/LP/FULL; 30-4kHz Crossover.
    Adaptive PWM Power Supply.
    Fully Complimentary Triple Darlington Output Stage.
    AP-IV Protection Circuitry.
    Forced Air Thermal Management.
    QBASS Plus™ Bass Boost.
    High Voltage Input Capability with -12dB Attenuation Switch.
    Gold Plated RCAInput and Output Connectors.
    PowerLock™ Speaker and Power Wire Connectors.
    Mixed Mono/Stereo Operation.
    Designed and Handcrafted in the USA.
    Power Bandwidth 10 Hz - 50 kHz
    Total Harmonic Distortion > 0.02 %
    S/N Ratio < 110dB
    Input Topology Instrumentation
    Input Sensitivity 150mv - 12 Volts RMS
    Input Impedance 10k Ohms
    Load Impedance (stereo) 2 - 8 Ohms
    Load Impedance (bridged) 4 - 8 Ohms
    Supply Voltage 11 - 15 Volts
    Damping Factor > 500
    Slew Rate > 50 V/μS
    QBASS™ Up To +12dB * 40Hz
    QBASS PLUS™ Up To +18dB Boost
    * 30, 36, 44, or 60Hz
    Crossovers 12dB/Octave
    Crossover Frequency 30-4kHz
    Idle Current: PCX 5800 2.5 Amps
    MODEL 4ohm STEREO 2ohm STEREO 4ohm MONO
    PCX 5800 4 X 50 4 X 100 2 X 200
    4ohm MONO 2ohm MONO
    5/Ch. 1 X 200 1 X 400
    * ALL POWER RATINGS SHOWN ARE TESTED * 12V; 4 ; 20-20kHz
    Aug 2011
    Aug 2010
    Ano meron dito?
    Aug 2011
    Quote Originally Posted by jhnkvn View Post
    Ano meron dito?
    Sorry, hindi ko na include yung question ko, haha! Nawala sa isip ko nung hinanap ko yung specs. Tanong ko lang po kung okay ba yung specs ng amp at kung magandang brand ba toh?
    Aug 2010
    All amplifiers sound the same as long as they have the same specifications: noise, THD, frequency response, watts, gain, etc. If the company is faithful in its spec sheet, don't mind what others say, it's a good amplifier.
    Precision Power was legendary back in the 1990s due to their Art series amplifier (PPI Art) which is still highly regarded even today as one of the best SQ amplifiers ever made. So they have their heritage. However, ever since then wala pa silang "hit" ever since.
    Depending on the price, there might be similar yet cheaper alternatives though. Price is always a factor ;)
Precision Power PCX-5800
