Results 1 to 6 of 6
- Oct 2008
- 83
March 13th, 2012 01:26 PM #1Sir,
Ask lang po kung paanu ma solve ang problem ko. 1st pag 35 volume or higher, nagproprotect ang mono amp. na sound magus Dk600, ang sub ko lang po kicker comp 10' dual. the 2nd problem minsan nawawala ang buong sounds then pag bumusina po ako. nagkakaroon po ng sounds. please help. thank you.
- Oct 2008
- 83
March 13th, 2012 05:42 PM #5
1. Gain setting too high is the most probable cause. Better thank that your speakers isn't blown yet. Either that or you're expecting too much boom-boom from a 10-incher. Protection also kicks in if you're entering clipping (ex. volume too loud) and the amplifier gets erratically hot (due to a sharp increase in power consumption). It always pays to know what volume you clip and avoid reaching that volume. As an example, I normally listen at 18-21 where 21 is the ideal volume for me to maximize a music's bit data. I avoid reaching volume 26 since would usually start clipping at that volume.
2. Grounding problem. Have your wires checked.
March 15th, 2012 01:01 PM #6
Pwede po na kinukulang sa current supply yung amp kaya nagpo-protect at high volume level, pwedeng low voltage, siguro nag da drop yung voltage nyo to 10volts kaya ganun, i think sa wiring yan kaya ganun, pwede rin na sobrang baba ng impedance na ni lo-load nung amp mo, 2ohm stable lang po ang amp na yan, baka naka 1ohm yung wiring configuration ng sub mo. Dun naman po sa nawawalan ng sounds then nagkakaroon pag bumusina ka, medyo mahirap hulaan kung anu problema nun, better pa check nyo po wiring nyo sa professional autosound installer.
