Results 1 to 5 of 5
- Aug 2011
- 374
March 17th, 2012 02:39 AM #1Guys, may nagbigay sakin ng amp na toh, newbie lang ako sa sound set
Specs:
Advanced Instrumentation Input Stage
TC-X Crossover 12dB/Octave; HP/LP/FULL; 30-4kHz Crossover.
Adaptive PWM Power Supply.
Fully Complimentary Triple Darlington Output Stage.
AP-IV Protection Circuitry.
Forced Air Thermal Management.
QBASS Plus™ Bass Boost.
High Voltage Input Capability with -12dB Attenuation Switch.
Gold Plated RCAInput and Output Connectors.
PowerLock™ Speaker and Power Wire Connectors.
Mixed Mono/Stereo Operation.
Designed and Handcrafted in the USA.
Power Bandwidth 10 Hz - 50 kHz
Total Harmonic Distortion > 0.02 %
S/N Ratio < 110dB
Input Topology Instrumentation
Input Sensitivity 150mv - 12 Volts RMS
Input Impedance 10k Ohms
Load Impedance (stereo) 2 - 8 Ohms
Load Impedance (bridged) 4 - 8 Ohms
Supply Voltage 11 - 15 Volts
Damping Factor > 500
Slew Rate > 50 V/μS
QBASS™ Up To +12dB * 40Hz
QBASS PLUS™ Up To +18dB Boost
* 30, 36, 44, or 60Hz
Crossovers 12dB/Octave
Crossover Frequency 30-4kHz
Idle Current: PCX 5800 2.5 Amps
MODEL 4ohm STEREO 2ohm STEREO 4ohm MONO
PCX 5800 4 X 50 4 X 100 2 X 200
4ohm MONO 2ohm MONO
5/Ch. 1 X 200 1 X 400
* ALL POWER RATINGS SHOWN ARE TESTED * 12V; 4 ; 20-20kHz
- Aug 2011
- 374
- Aug 2011
- 374
March 17th, 2012 05:46 PM #4
March 18th, 2012 10:32 PM #5
All amplifiers sound the same as long as they have the same specifications: noise, THD, frequency response, watts, gain, etc. If the company is faithful in its spec sheet, don't mind what others say, it's a good amplifier.
Precision Power was legendary back in the 1990s due to their Art series amplifier (PPI Art) which is still highly regarded even today as one of the best SQ amplifiers ever made. So they have their heritage. However, ever since then wala pa silang "hit" ever since.
Depending on the price, there might be similar yet cheaper alternatives though. Price is always a factor ;)
Tentative price increase from removal of the pickup tax exemption leaked:
Toyota Hilux (9th Gen)
