Results 1 to 10 of 29
September 13th, 2012 08:04 AM #1
Sound deadening project... DIY lang
took me two days to fully deaden the 5 doors of the eve and all the flooring...
my father also helped in the process, kaya less work...haha..
asphalt based sound deadener ( 14 pcs all in all)
doors
after vacuuming and removing dirts under the carpet, installed the deadener on the flooring
well worth it... ang tahimik sa loob cabin... sumakit kamay ko dahil daming clips nang mga plastic trimming
need to be careful dahil madali maputol mga clips.
i also put fiber glass insulation in between the asphalt deadener and the carpet for additional acoustic and heat insulation.
i can vouch now na meh difference ang sound deadening.
- Apr 2008
- 1,557
September 13th, 2012 08:30 AM #2
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 13th, 2012 10:39 AM #4gano kabigat yang sound deadening na yan? baka tahinik nga pero lakas naman sa gas
- Jun 2010
- 321
September 13th, 2012 11:23 AM #6
the sound deadening material is around 2.5 kilos each... so 14 pieces would weigh 35 kilos... wala naman problem about sa added weight dahil diesel eh, malakas torque...hindi ramdam ang additional na bigat... that's another story pag gas ang kakabitan.. hahaha.
madali lang naman, nilakasan ko lang loob ko, tapos very very careful sa clips, and then tandaan lang what clip is for what panel para di mag halo halo... first time ko din hubaran yung everest namin... ang saya saya sa loob very peaceful, kahit diesel parang luxury, pati pag close open ng doors buo ang tunog...
after go magawa hindi naman pala ganun ka tindi o hirap... talagang magpapawis ka lang...
meh kakilala ako nagwork sa deadening material factory sa kanya ako bumili.... mas mura siya sa mga shops at tindahan... ang laki kamurahan... 250 per panel...
- Feb 2003
- 1,038
September 13th, 2012 12:48 PM #7Bro, based on pics seems not included dyan ang ceiling?...or was it included hindi mo lang napicturan. Comparable na ba to sa EU cars ang closing ng door? Congrats very satisfying DIY yan.
September 13th, 2012 01:27 PM #8
- Jan 2008
- 4,726
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
