Results 1 to 20 of 23
    Oct 2007
    guys hello po sa inyo
    gusto ko po sana mag tanong at mag pa turo sa inyo
    i have my first car mitsubishi galant, im a student and medyo
    low budget,,
    gusto ko po kasi sana sa SOUND SETUP ng Car ko is
    yung MALAKAS PO yung BASS
    kasi po more on HIP HOP AND RNB ang pinapatugtog ko
    kaya mas GUSTO KO PO MALAKAS YUNG BASS,,,
    kasi po nung minsan inasar ako nung frend ko na nag ttrycycle MAS MALAKAS PA DAW SOUNDS NYA SA SOUNDS NG CAR KO kasi yung
    sounds ng car ko walang BAYO / BASS ...
    so medyo nakapag ipon ipon na po ako ng konti gusto ko na sana
    pa setup yung sounds ng car ko...
    ano po ba ma rerecommend nyo para sakin, or baka my kakilala kayo
    refer nyo po ako,
    wala po ako kasi ka alam alam sa kotse...
    ano po ba dapat ko bilihin na brand ng speakers ampli?
    anung size? wats? basta po more on BASS
    i hope someone can help me...
    thanks po...
    I would recommend at least 500 watt amplifier and about 1500 watts subwoofer. I had a JBL amp and woofer previously. They're really good.
    Jan 2004
    What's your budget sir?
    My friend has Alpine amplifier and subwoofer. They're also very good but quite expensive. You can buy a twin subwoofer (2 speakers) with port (air outlet) for deeper bass. For the amplifier, get a double LINE OUT (one for subwoofer and one for car speakers).
    The wattage for the amplifier should be lower than the wattage of the woofer, otherwise you might damage the subwoofer.
    Nov 2007
    If you're from southern tagalog, punta ka sa Kid Audio (Binan, Laguna). Although I heard they get customers even from the north (Pampanga). They'll ask you for your budget and what kind of output you like, then kaw na bahala mag-decide. Malinis ang gawa tapos may final quality control pa by Mr. Kid himself. Pero dapat wag ka magdala ng credit card kasi sigurado tataas ang babayaran mo. Hehe.
    Mar 2007
    Quote Originally Posted by ent_md View Post
    agree with ent md, all will depend with the customer, discuss mo lang kay kidd gusto mo with your burget.
    Aug 2004
    bigay ka muna ng budget and location mo, bro para mas madali makapag recommend mga tsikoteers sayo.
    Quote Originally Posted by pespiritu View Post
    excuse me sir, bakit sabi ng iba mas ok daw na mas mataas ang rating ng amp kesa sub? Para daw mas "busog" ang sub. Hindi naman itotodo ung amp dba?
    Aug 2006
    AFAIK: the amp must be a little bit higher than the subs be careful lang sa gain!!! this is the only way to get the full potential of the subs!!!
    in my case:
    1012= 400rms *4
    DLS Ultimate A6
    The dual Mono Amp
    RMS output at 13,8V, 20Hz-20kHz, < 0,1% distortion
    Mode : AB
    Number of channels : 1 ( for subwoofer use )
    Nominal power in 4 ohm : 500 W
    Nominal power in 2 ohm : 870 W
    Nominal power in 1 ohm : 1200 W
    Fuse: 4 x 35A (underated this thing can go up to 600w in full!!!)
    so overkill nga yung amp diba buti nalang kayang ihandle ng DD ang 600w kahit rated 400w lang sila
    Oct 2007
    sir mkikisingit lng me sa usapan gsto ko lng mlaman opinions nyo kse nkabili n ko ng isang pair ng infinity6020cs reference tska pair na 6x9na infinity9623I reference dn ngaun sakto lng b yn sa JBL CS60 na amp eto ok nb toh sa SQ? tpos howmch ung pa wiring ky jef tan? plan ko kse ky jef na ko mg papawring
    Aug 2006
    sorry late reply!!! try to ask jeff nalang baka may iba pa syang masusugest sayo
    contact no. posted above good luck sa set nyo boss!!!
    Oct 2007
    ky c&j autosound me bumagask hehhe dun ko bnili ung mga wires fuse laht n kelngan, kaso babalik p ko dun, papakbit ko ung seps ko uung 6x9 plng nkabit nmn ehh.... hehehe kta kits nlng sir sa dec 1 manonood me....
    Oct 2007
    Aug 2006
    ah ok sir!!! congrats and see you sa aniv!!!.
Need Advice for my Sound Setup !!!!!!!
