Are stock 06 Civic head unit amp ready? Im not much of a car audio buff but I would just like to boost my sound a little (1 amp, 2 speaker, sub setup)Recommendations would be appreciated. Thanks
sir, you can check the rear end of your head units if it has RCA outputs. usually low end models would have only two (rear left and rear right). you can use Y cables for your speaker and sub set up. then use the low pass filter of your amp for the sub na lang.
