Results 1 to 19 of 19
    DIY ba ang pagpalit ? madali lang ba palitan ang HU ng REVO? hinuhugot lang ba ito then saksak lang ang connections?
    Or do i need a specialist to do this stuff?:confused:
  2. #2
    You have to remove parts of the console to be able to remove the HU. Don't risk it... I suggest you bring it to a specialty car audio shop, and have them do it. There are Intense, Pony, Mickey's, Mach2audio, etc.
    Meron ka na ba ipapalit? Or bibili ka pa lang. If you'll purchase one pa lang, you can have it installed in the same shop you'll buy it in for a minimum amount (if not for free).
    Sir Paolorenzo,
    Saan ba itong:
    Intense, Pony, Mickey's, Mach2audio?
    Any contact numbers pls.?
    intense is along banawe
    tel# 7316479
    mach2audio
    8 main st, chason subdivision, pasig city
    tel# 9150683
    (katabi ng south super market sa amang rodriguez)
    mickey's autosound
    located along amang rodriguez
    (halos katapat naman ng south super market)
  5. #5
    Pony naman is inside the Auto Centro compound, right across Ali Mall Cubao... 911-2249/912-6302
    ako nagawa ko..DIY hehe...you need to pull out the whole
    dash board...it took me 2 hours to change the HU...dali lang
    yan......hindi mo kasi mahuhugot basta basta yung HU
    Sir Ozcity,
    Nahirapan ka ba sa pagbaklas ng Whole Dash board? all screws and bolts lang ba yun? ano ba dun parte ang maselan? at pakakaingatan ko. madali lang din ba ibalik? 2 hours, hmmm ? medyo mahirap ata ah?anyways i-try ko lang.
    eyescube::: Ano po ba ang brand ne HU nyo? Napansin ko yung ibang Pioneer units, will need a couple of metal sticks to unlock the unit. Kahit na hindi baklasin ang buong dash panel. But some vehicle makes and models will need some panel access just to remove the unit.
    agree ako sa kanila.. dun mo na lang pakabit sa bibilhan mo ng bagong HU.. pero kung kaya mo eh go ahead..
    matagal baklasin dashboard ng mga revo dahil isang buo ito.. nakita ko na matanggal yung sa amin..mismong sa toyota casa eh nahihirapan sila.. meron 2 screws sa top ng dashboard (kelangan mo tanggalin yung cover) then sa gilid ng dashboad eh maraming screws tatanggalin..
    meron part na mabibiyak sa loob ng dashboard.. ito yung tatlong screw na malapit sa windshield na di natin kaya tanggalin.. pero pag binalik mo naman dashboard eh ok naman at walang kalampag..
    pag tanggal na pala lahat ng screw eh eh hilahin mo yung dashboard at wag yung pa-angat... then you have to disconnect the clock..
    sabi sa casa eh mga around 8K daw ata yung dash board pa lang.. kaya konting ingat lang..
    wala naman nasira dun sa pag alis ko ng dash board
    meron din screws yun sa loob ng glove box..
    yap all screws ang bolts lang yun..hindi naman mahirap
    diskarte lang yan...wala naman maselan eh...mas maselan yung pagpapalit or wiring nung HU..baka hindi match yung harness ng new HU mo so u need to cut the wires of the old harness..
    wag mo kakalimutan tanggalin sa connection yung baterry mo
    while pinapalitan mo na yung HU..para safe ka..
  11. #11
    Grabe revoGSX!!! I had a CD changer installed at the Toyota Casa (for warranty purposes), and I observed the installation process. Ang hirap pala talaga tanggalin ang dash ng Revo! You're right, 1 piece nga. Sobrang daming switches pa to disconnect! Nakakatakot kasi baka hindi mabalik ng maayos. I was so worried na baka meron kalampag afterwards. Ang dami pang screws, I had to watch closely, baka di mabalik lahat.
    Bilib ako kay ozcity... lakas ng loob.
    hi paolorenzo,
    mahirap talaga baglasin dashboard ng revo.. sabi nga ng mga mechanic sa casa eh mali daw design dahil lahat baklas at meron 3 screw hole na mabibiyak.. nakita ko na din kasi nung binaklas yung dashboard ng dad ko sa revo GL 2000 nya.. nasira kasi radio dahil natuluan ng tubig (meron cup holder sa aircon) ..
    sa dec 16 eh ibabalik ko itong revo gsx namin sa toyota makati para i-check yung static sa speakers when operating the power side view mirror... babaklasin ulit nila dashboard..gagawin nila habang nandun ako.. di na pumayag iwan sasakyan eh..
    kung nandyan lang ako tulungan ko kayo..pa jolibee lang ok na..ehehehehe..wala naman nasira or nabiyak dun sa
    dashboard. wag kayo masyado papaniwala sa casa..hehehehe
    yung sa inyo ba may stock tweeter na nakalagay sa
    side panel? diba may 4" speaker sa ibaba then dun
    sa itaas may tweeter?..binuksan ko din ito tapos
    nalaman ko yung isang side lang ang merong tweeter
    sa loob(driver side) pero yung sa kabila naman walang
    laman sa loob...dummy lang..kaya ginawa ko bumili
    ako ng tweeter wala pa yatang 100pesos
  14. #14
    Susmaryosep! 4" lang ba ang stock speakers sa Revo? Would you know if it's the same for 2003 Revo? Tagal na namin sinusubukan alamin yan ni revoGSX eh.
    I-flashlight ko nga tomorrow yung VX kung dummy nga talaga ang tweeter sa passenger side...
    Salamat master ozcity...
    pre im not sure kung 4" or 6" yung front speaker..medyo
    maliit kasi kaya nasabi ko na 4" lang.....try mo na lang
    pakinggan yung tweeter kung tumutunog...badtrip nga
    nung nalaman ko ung kabilang side e dummy lang...
  16. #16
    ah ok. sa estimate ko kasi, 5¼" siya eh...
    Nag-wi-window shop na ako ng possible replacement speakers eh. Seps siguro, with crossover, para palit both speakers sa front door. Pero di na ako mag-a-ampli.
    mga sirs..
    dun sa 2003 revo namin eh meron naman tweeter both side ..nakita ko nung ni-check ng toyota makati yung static noise problem sa alpine 7871R ...
    ng makita ko yung stock speaker sa front door... walang tatak at parang mabibili mo lang sa tabi ng raon .. 24watts at mga around 4inch nga... pangit pala itsura ng mga stock speakers ng revo hehe..
    then dun sa ni-check ko yung stock speakers sa 2000 GL ng dad ko.. kelangan tanggalin sideboard dahil nagloloko na doorlock.. fujitsu ten ang tatak ng speakers at 20watts and 4inch.. halos parehas din itsura nung 2003 model..
    Feb 2005
    posible ba lagyan ng 6x9 na speaker ang front door ng revo ..at hindi kaya masira or pangit tinggnan ..thnks in advance
    pwede bro.. kung gusto mo pagawa ka na lang ng box na mallit para sa 6x9's tapos isingit mo sa mga singit singit hehehehe
Paano magpalit ng HU ng REVO GLX 2000 model
