sorry kung may nag post na ng ganitong question hindi ko kasi maintindihan ung mga naka post dito e. here my question
balak ko kasing i set-up ung sounds ng auto ko but wala ako ganong alam sa mga speaker or subs gusto ko sana you chill lang yung tunugan ng auto ko. gusto may bass lang para bumabayo at lumalabas ung tunog pag rnb ang pinapatugtug ko minsan rakrakan din pinapatugtug ko ano ba ang magandang setup para sa ganong klasing tugtugan ung swak sa budget. pa help naman po
ok na po ang 30 k budget dyan kung kaya nyo, or kung budgeted lang, 15k po ok na yan, without head unit, these include, a seps, sub, 4 channel amp, subwoofer box, and wirings. look at the deal of sir jedi.
tama si tsikotshop. advise ko punta ka minsan sa kanya (near tesda, taguig) para makapili ng swak sa budget mo tapos deretso pa-install mo na. ayus yan si tsikotshop!
You're looking for a SPL setup rather than a SQ setup.
If you're new, I suggest doing it slow. Allocate around 20-30k muna and then upgrade if you feel you "want more". I would suggest JBL, Kicker, or RE brands at that price range.
Read around the forums and get the overall idea on how the setup is.
First upgrade should always be the HU. Follow this with a good pair of separates. Don't go coaxial, any setup benefits from a perceived wider sound stage brought about by the separation of the treble from the midbass. Next, get an amplifier. I would suggest Powerbass. Clean sounds but it can really thump, Rockford Fosgates is a notch better but the premium demanded would make you fork out more cash. As for the subwoofer, pay attention to the box enclosure. Even a 8 incher would suffice for the daily bass needs (as long as hindi ka yun windows-down-bass-thumping) but I'll suggest getting 12 inchers for the sweet spot.
Remember, a good subwoofer beats out 2 or more inferior subwoofers good luck. Also, the most important part of your setup is not the separate nor the subwoofer.. it's the amplifier. So make sure you get a good one.
ok na po na setup ko around 20k na gastos ko lahat lhat ask ko lang po kung saan meron at kung anong name ung pang tapal sa compartment para hindi tumunog?
Door deadeners? Madami dami dyan. Like Dynamats, Stinger Roadkills, etc. good investment sila pag30k+ na sound system mo. Mahal din kasi sila so paglow-end setup, it's better to use the cash for a better set of speakers.
