Results 1 to 8 of 8
- Jan 2005
- 10
March 7th, 2005 04:07 AM #1wat shud be the specs of the amp i need to buy for this kind of sub specs
2 pieces kicker 12' subs
Key Features
Type Component
Function Subwoofer
Size 12"
Nominal Power Handling 150 Watt
Powered Non-Powered
Technical Features
Peak Power Handling 300 Watt
Frequency Respond 25 Hz - 500 Hz
Sensitivity 88.6 dB
Impedance 4 ohm
Components
Woofer Material Poly / Plastic
Surround Material Foam
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 5.5 In.
Mounting Diameter / Length 10.88 In.
thnks be buying jbl amp soon kasi or other branded amps for the subsLast edited by snapper; March 7th, 2005 at 04:18 AM.
- Jul 2004
- 241
- Jan 2005
- 10
March 9th, 2005 02:45 AM #4bit of both
maganda sound quality pero bumabayo din when needed
budget 6k
March 9th, 2005 02:55 AM #5
Bro, if you can source an old school amp then go for it, swak sa budget mo yan. Daming ok na brand like soundstream, precision power, etc.
- Jan 2005
- 10
March 10th, 2005 01:36 AM #6its kinda hard to find the proper amp na kailangan ko pag 2nd hand bibilhin ko
kaya im planning to buy jbl amps na lang
ok ba ung jbl amps
March 10th, 2005 01:46 AM #7
Problem with getting a brand new amp is your budget, baka kapusin ka. You will need at least 150watts each for your subs to maximize it.
Si the_wildthing naka kicker subs, gamit ata niya rockford punch not sure tho.Last edited by ILuvDetailing; March 10th, 2005 at 01:52 AM.
- Jan 2005
- 10
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
