Results 1 to 9 of 9
    Jun 2008
    need help lng po pra s setup ng sony GT670US n nabili q, confused kc aq pra s full setup ng xplod prang d maganda feedbak. if ever n bibili aq ng other brands n amp and sub what do you guys can recommend for 15K budget? kasya n kya un or do i still have to stretch out little bit more my budget?
    I read somewhere in this forum n pwede p rin magamit un stock n speaker lets say ung s gli q & then add n lng aq ng decent amp and subs. (nagtitipid e... hehehe!). Or do i have to replace my front/rear speaker, add sub and amp?
    I was looking forward para s SQ level of listening pleasure. Lol!
    swak kya ung budget q?
    sir first of all... please dont use text language. hirap basahin yung post. thanks...
    anyways, if your going for SQ na budget meals then ok na 15k basta hindi kasama HU.
    seps, lanzar, or targa
    amp, v12, fenton, jbl basta rms niya 500 watts and 4 ch
    subs, targa or phoenix gold. get the 12" para hindi mabitin sa bass. also sealed type na box.
    i think pasok sa 15k yung gantong setup... with power supply, cables, and labor.
    yung coax... wag mo na galawin, let it be run by the HU.
    hth
    Jun 2008
    sorry for the composition of my upper post. medyo nasanay e.
    anyway, another question sir, what particular wattage ang dapat kong bilin for seps and sub? di ba ok iyong 2 channel na amp? meron kasi akong nakita na amp 2/1 800watt medyo tempting na bilin. what's the difference between 4/1 and 2/1 amp? pasensya na at wala akong masyadong alam technically sa sound setup.
    EDIT:
    thanks for quick reply
    with the wattage question... ok na yung mga 125 rms watts na seps... it can do the job right kasi bubusugin mo sa amp yun. then for the subs, go for 300 rms watts. pili ka na lang ng seps na tama for you kasi maraming seps with different sounds. mas maganda to audition all that you can then pick at the end.
    with the amp 4/1 means 4 ch bridgeable then 2/1 is 2ch.
    parang ang lakas ng rating for a 2 ch amp yung 2/1 na sinasabi niyo.. baka peak power na yan. that means nothing, kailangan mo yung rms rating. what is the real specs on those amp you were tempted to buy?
    ok yung 2/1 na amp pero yung 4 ch kasi kaya niya yung seps and sub... so kung 2/1 ka, dalawang amp kailangan mo. one, to power the subs then another to power the seps. double gastos.
    baka tanongin mo din kung ano rms
    rms: i forgot the term of it pero its the continuos wattage it can produce.
    Jun 2008
    it seems clear to me what I will do next. I recently saw the 800W amp in one showroom of sony (IMO, maybe total maximum output iyon... I forgot to ask).
    Now, I better go shopping for a 125W seps, 300W sub, decent amp having 500W (RMS un ha... hehehe!) right?
    thanks!
    rms=root mean square
    nako sony pala... most probably, peak power ang stated dun. like with their subs... sabi 1300 watts, pero peak lang yun.
    yep yep, those will do para pasok sa budget mo yung set up...
    try c3 audio sa banawe katapat ng dencios. ok yung prices nila. another is yung kay jeff tan. never ko pa nasubukan yung kay jeff tan pero ganda feedback ng tsikoteers.
    no prob sir, good luck sa sounds shopping
    edit: ^^ ayon yung meaning ng rms.
need help for a newbie :)
