Results 1 to 10 of 73
October 11th, 2007 10:12 AM #1
Hi Peeps,
any comments on my Setup?:
Focal Front separates 6" w/ cross over
Kicker CompVR or VT (slimtype version of VR) in a ported box
disable ung 6x9 speakers ko (or follow up question below)
RF 4 channel Amplifyer to drive the separates and Sub?
* di ko pa naaudition toh eh, pero mabayo na ba toh? and is the sound ok? boom boom na ba toh? or i'll switch pa rin my subs? (honestly nag hhesitate ako kung mag DD ako, pero i'll try to i-audition muna sa mga KAC folks)
but basically, yan ung simpleng set up?
question:
1. tama ba na i-disable ko ung 6x9 ko?? or still i-upgrade ko pa rin xa? pero hindi ko na xa maddrive nung amp right?
2. ok lng ba na may floating na 1 channel sa Amp? kc 1 sub setup lng ako..
Thanks, comments and sugestions are accepted... hindi naman budgeted ung price, hindi naman medyo pricey, ung tamang middle range setup na xa ranging from 20-25k? Handle ko is Honda City 97
October 11th, 2007 11:41 AM #2
Why disabled the 6X9? Since you have a 4-channel amps, run with 3 channel mode and let your H.U built-in Amp driving your other two speakers.
Example.. Your 4 channel amps
2 channel or your amps run each speakers(front or rear)
The other two channel of your amps(bridged) is for your subs.
Run your other two speakers front or rear with your H.U. You could choose diff kind option by using your own design strategy.
October 11th, 2007 12:28 PM #3
hindi kailangan na maging floating yung isang channel ng amp mo. bro. bali use 2 channels for the front seps and bridge the remaining 2 channels to drive your sub. yung sa rear mo kahit yung HU na mag drive nun. IMO, mas ok parin ang DD compare sa kicker sub.
October 11th, 2007 12:51 PM #4
tama sila bro, i connect mo sa head unit mo ung 6x9 mo. ung 4ch amp mo, ung 2 dun para sa seps mo and ung 2 para sa subs mo, ibridge mo lng, hndi kc kakayanin kung 1 channel lng gagamitin mo sa subs.
October 11th, 2007 02:48 PM #5
ah ok, hehe pero as far as ung parts, ok na ung model? and also as far as sound boom boom is concerned? any comments, especially dun sa Kicker sub? may kontak ako sa KAC eh, drop by daw ako sa sat sa EB nila, para maaudition ko ung DD subs, kaso mahal eh, 7k ata ung lowest eh, tpos sumunod na dun mga around 11-12k eh.
tpos papadeadenning pa ako, and btw, gus2 ko kc minsan patay ang ang audio, (what i mean is subs, ampli, etc.. speakers lng ang ttunog, kc minsan ksma ko lola ko eh, bka atakihin sa puso pag biglang bumayo eh, ahaha
October 11th, 2007 05:24 PM #6
October 11th, 2007 05:57 PM #7
lol, nawla ung edit button eh:
update ko lng specs ng project ko:
Focal 165CA(coaxial) or 165A1?
1pc 12" kicker CompCR or CVT or 1pc 12" DD (unknown model subwoofer)? in a ported box or? (solid bayo na gapang effect na box, any comments?)
RF P00-4 or JBL GTO 75.4?
additional:
1F capacitor
Deadening
SPL target ko, tama na ba yang set up ko? overpower pala ung RF T8004 na ampli (tyka overpricy na rin para sa akin) konting help naman po? para mafinal decision ko na kung anu tlga setup ko, kc malapit ko na matpos ung ipon ko pra derecho na ako sa pagpapagawa ng kotse, at walang hesitations...
btw, any suggeted shop/s? to buy and for them to install all my setup? default ko is Mickey's or Ginza
Thanks po,
*TooLights,
dude help naman sa pag identify ng subs ng DD, kc pricey na sa akin ang pag umabot ng 10k sub pa lng eh, if ever kcng taas or more power kesa sa kicker CVR's
October 11th, 2007 08:01 PM #9
IMO
DD in a phat box or snailshell
pag ported with right tuning lakas nito!
di ata kakayanin ng 1 amp ang setup niyo sir,
maganda siguro JBL GTO for your focals
mono amps for your DD/kicker
basta busugin ang sub
kakayanin ng 1 amp pag T8004 gamit
entry level ng DD (DD500) + Focal seps
di overpower yan depends parin sa source kung 12v ang input
assuming na true power output ang RF
pero mas ok siguro ang hiwalay na amp para labas ang full potential ng sub
alam ko sir toolights KAC sure na maraming alam sa DD yan
correct me if im wrong ha
.02
ok din kay jefftan ng ACA sarap budget meals
OT
*sir toolights sir anung sa tingin niyo sa CRUNCH amps? parang mura siya a
planning mag upgrade hehe
Tsikot Member Rank 3
- Jul 2004
- 1,540
October 11th, 2007 11:54 PM #10Since SPL target mo i would recommend DD 512, 7,400 price nito. 250 watts rms lang to but you can power it to 400 to 500 watts para mabusog. Tapos sa box phatbox or abc para bayo talaga.
Yung Focal seps na lang kunin mo mas okay yun kaysa mag coaxial ka.
With regards to your lola's heart, sa HU naman ma ooff mo yung sub kung sakay mo lola mo. This is what I do pag kasama ko parents ko sa kotse, usually off yung sub or mahina lang yung setting ng sub
Nakakakilabot yung bagong srps taking into consideration na mag-10 years na ang current model neto.
All New Toyota Hilux
