Results 1 to 17 of 17
    Jul 2006
    help po mga sound enthusiast..ano po babagay na amp, seps, rear, box with sub, and LOC.. 20k-30k na budget ...that can produce SPL & SQL combined pauwi na kc ako from aussie i want to upgrade my sound on my mazda 3.tnx in advance
    an all JBL GTO system is within your budget
    GTO 75.4 4 channel amp around 11k
    GTO 6507 separates around 4.5k
    GTO 1202d subwoofer around 3k
    but since your budget is at 30k, i would recommend upgrading the separates to:
    JBL Power series seps
    polk audio db seps (loved how this seps perform) around 8k
    the GTO seps are very bright (matining) and you have to have a decent HU to control it.
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jul 2006
    thanks for the reply caloyski5..but unfortunately OEM headunit gagamitin ko bili lang siguro ko ng LOC na medyo matino.. i also read ung mga naka targa setup ok naman daw di ko lang alam kung quality and can be used for years...
    Jul 2004
    for 20-30k budget
    Seps: Entry level na focal not familiar what model pero sure na sq yan or you can also try morel tempo mga 9k either of the 2 parehong entry level pero sure SQ.
    Amp: Solid Audio 4-channel. f45 ata? around 12-13k ata
    Sub: DD 512 sure na less than 10k
    box and wiring na lang kulang. Add more or less mga 3k for box and around 2k for wiring siguro. Sure na satisfied ka na diyan. hth
    I was at the Ace Hardware (Makati/SM) last week. Meron sila demo unit na Sony Xplod. Lahat-lahat nasa P29K daw, at 2 pa ata subs nu'n. Dumadagundong!
    Jul 2003
    i would steer away from the sony xplod, mas ok yun jbl setup na sinabi ni caloyski5. focal,morel or dls for seps ok daw kng kasya sa budget.
    Jun 2006
    Caloyski's suggestion is good. I recommend replacing the HU with a Pioneer DEH-4950 around 5K.
    Try to audition different speakers before buying. That way you have an idea how they sound. I will also pour the money on the speakers. Its what you hear.
    Jul 2006
    well thanks mga fafa...mas ok sana focal or morel for the seps ksso di na talaga aabot sa budget papalit pa ako mags and tires from 16" stock to 18" im keen of using my OEM ok naman sya...regarding sa rear pede bang stock speakers nalang o palit din? Malamang i'll stick to caloyski suggestion...sana ok din mg install ung shop ni jeff tan doon kc ako balak bumili ng items.
    Jul 2003
    pwede rin stock sa likod since nasa harap ka naman usually... im planning to replace the speakers din ng mazda 6 kaso nanghihinayang pa ako ksi bagong bago pa e.
    Quote Originally Posted by lolidus View Post
    Since SQ and SPL gusto mo, parang loud and clear ang ideal setup for you. Maraming nagsasabi ok daw ang straight JBL for this setup. Aside from the one who posted ng all JBL setup, hindi ko sure ang price pero you might wanna see if kasya sa budget mo ito. JBL powerseries seps sa front and rear. Then naka powerseries subs din in a phatbox. (Try to look for djphatbone pag uwi mo)
    Goodluck with your project!
    check ka dito for prices, more or less diyan naglalaro ung mga price.
    http://www.cgena.com/pricecomp/viewB...=3&fact_id=165
    Aug 2004
    seps: focal access 165a1 - P8900
    4ch amp: jbl gt075.4 - P9000
    sub: jbl 1202 - P2k+
    yung rear speakers mo pwede yung stock nalang. bali yung idadrive ng 4channel amp mo is yung seps and sub nalang.
    Jul 2006
    thanks mga bossing i narrowed my seps to 2 brands which polk audio db series 9k yata price or focal access 165a advise by mcbry... i'll stick to the stock speakers sa rear..ung amp cguro maganda n ung 9k na gbl GTO series...decent amp na kaya to power up seps and subs..?
    If you're going for focal and rear stock speakers, then SQ na kalalabasan ng setup mo. If you want in between SQ and SPL, better off with JBL ka.
    Goodluck.
    How about Blaupunkt GT series for Separates? Im using a BP GT series for my Seps and BP 3 way for my Rear, (tpos Pioneer na HU, wahehehe kapoz budget for that) Ok na xa, Rinig na xa sa labas, Problem ko lng is BUmabayo rin ung Seps eh, so prang Tumama ung Cover ng Door sa spearker pag Bumayo, tyka Uhaw sa Ampli, pero ok na xa, kc prang Same tau ng Project, SQ sa Loob, SPL sa labas? tama ba? Nilimit ko lng kc ung budget ko for SQ kc, i22do ko xa sa SPL,
    Btw, anu maprefer nyo na Amp for my Separates? 4 way para maddrive din ung sa Rear ko, ung maliit lng ung size, kc sa Side ng Trunk ko lng xa immount, dahil gus2 ko pa rin mag lagay ng Spare Tire sa Likod, kahit na may Sub/s na ung car, prang ganito, | O |, ung | | ung Ampli (for seps, and for Sub) tpos ung O ung Sub, (xempre di q na nilgay ung Spare, di ko lam panu iddrawing eh, hehe..
    Jul 2006
    regarding this thread..i cant really make use of those good speakers/subs that will be powered by my amp...i think im neglecting something about the line-out converter so i could use my stock HU of mazda3 which cannot produce speaker level inputs so I need LOC to be connected on my amp then connect it to the speakers/sub? my question is that is their any available amp that produces high level input or a built in LOC so i would not bother buying a LOC ? thats the case in stock HU of mazda.
    Aug 2004
    mura lang naman price ng converter nasa around 450-950. stock HU din gamit sa altis namin then dls na amp. ganda naman ng pagkaka sq ng sound system namin.
20k-30k sound setup for mazda 3
