Results 1 to 14 of 14
    Bumili ako kicker one CVR 12inch 4ohm in parallel so bali 2ohm na siya tama ba? then my amp pag naka bridge is 4ohm recommended minimum. Ano gagawin ko dito? single channel lang ba gamitin ko sa sub ko pero bitin. Please help. Thanks
    Apr 2011
    Quote Originally Posted by whizkidd View Post
    IMHO, You can try wiring the coils in series to make 8ohms. This way, you use both coils of your sub and both channels of the amp (bridged) as well. Bitin nga lang bass pa rin pero at least walang nabakante na coil/channel and you won't fry your amp.
    May 2011
    Not sure if the X12-MRV1507 is 2ohm stable, I would suggest you sell the amp and get an AMP that is 2ohm stable, di mo makukuha yung peak performance of your sub, sayang lang.
  4. #4
    You can used it with that amp by stereo mode, do not parallel the subs, just put those two voice coil in every channel so you got stereo mode, ingat lang po sa polarity, anu po ba yang amp nyo, 2 cahnnel or 4 channel? Maybe kelangan ko ng mas maraming detail about dito para mas marami akong maibigay na idea, ilang watts ba yan per channel? Your sub is 400watts rms dual 4ohm.
    *thnx for the reply.
    By the way 4channel ang amp ko 3600 watts nakalagay at bridgeable. Naka power ang 1/2 channel sa front and 3/4 channel sana sa sub. Na try ko bridge malakas pero parang mainit yong amp. At kung using the channel in each coil safe po ba ganito? Paano kung mahina isang channel? Or mas ok ba gamitin left channel lang gamit lang ako Y splitter para sa input ng subwoofer para pareho ang signal?
  6. #6
    4 channel means, lahat ng signal output nito is the same, say, 80watts rms times 4 speakers, *4ohms... kung V-12 yan, the 3600watts is the peak combined power na imposibling maabot ng amp kase nasa 12volt current tayo, unstable.. the very option here is that, the stereo mode, safe and effective para sa amp mo, kase naka 4ohms lang, kapag nakaparallel yan, 2ohms na, possible is, mag dc out yang amp katagalan, kaya ng MRV 1507 yan but not for the long run. Palagi kong ginagawa is the stereo mode, THD or the signal to noise ratio is ok there, unlike bridging it, una, power supply mo, maintain mo is 14volts para stable sya dun, pero, if your drawing 300 watts current, sigurado, putok fuse nyan for two or more hours. then the DC out. Stereo mode pare, solve na yan, kung may extra budget ka, go for the mono AMP, mas ok..
    May 2011
    Correct me if I'm wrong pero I don't think putting the DVC Sub on two different channel is advisable and safe (Stereo mode)... Not all the time, channels 3 and 4 will send the same signal to make both coils work the same frequency. Most music (R&B for example) are using a flanging effect causing one source (either left or right) to be delayed by a millisecond. Voice coils of speakers only have two movements, up or down.
    Picture this: Ever heard of some IASCA CDs or the Madonna remastered CD? Borderline's intro for example (as you'll hear it) has this effect of traveling sound from left to right then back to left then right again, it's goal was a moving synthesizer. Now imagine if you put one coil of your sub on say, channel 3 (left) and the other coil on channel 4 (right), each channel will send different frequencies & gains to achieve the output. It will definitely put stress to the Sub's coil as they will move differently but the coils are held together; resulting in fried coil or busted AMP.
  8. #8
    Yes, I got you but not in low frequencies, the low pass frequency trowing only mono channel, meaning, never in left or right or rear or front, bass frequencies doesn't have a location, in a perfect room, you never locate the bass, because it's everywhere. if and only if, your amp filters only good low pass, i don't think V-12 can do that because it has a low quality filter unless your using another filter like active crossover or your head unit has a subwoofer output, in a subwoofer output, it sends only low pass signal or mono, so you imagined now if you used these output to the 3&4 channels of your amp, what would be the output? Syempre, mono pa rin, no left in right issue..
    Apr 2011
    Ok rin yang scheme na yan ser. Agree ako kay ser Fotonista na not all parts of a song play on both channels simultaneously. So, go for the Y splitter para parehas signal ng both channel unless may mono switch sya which I doubt has any. And make sure na same ang polarity ng coils mo as per ser Tsikotshop. Yan ba yung pulang amp na marami sa raon? Ingat na lang ser not to push it too hard kasi putukin yung switching IC nyan. It's a pretty loud amp medyo wag nga lang birit palagi.
    I think i will do the Y splitter using left channel source only to 3&4 channel on amp and drive each coil per channel. Thanks guys especially to tsikotshop, fotonista and bigpapa. God bless.
    May 2011
    Quote Originally Posted by tsikotshop View Post
    So it's MONO and not STEREO as your first suggestion na "you can use it in stereo mode".
    Btw whizkidd, ano pala headunit mo? Agree with bigpapa, putukin yang MRV-1507, mas stable pa yung MRV-805. for the meantime use it, then ipon ka konti to get a decent amp na stable sa 2ohm when bridged, around 5K, ayus na ayus na yun (benta mo 1507 ng 2K, ipon ka 3K).
    If I we're you, I'd rather run my sub in parallel (8ohm) then bridge the AMP's channel 3 and 4. Dunno how the MRV-1507's wiring goes but usually, positive of channel 3, negative of channel 4 to have a bridged output. No more Y splitter. With this setup, you won't sacrifice any of your equipment, just the sould quality (less bass).
    Apr 2011
    Quote Originally Posted by Fotonista View Post
    Agree ako kay sir Fotonista. If you chance upon a really old-stock V12 MRV-????, buy it! Specially the first version of V12's. They're the silver gray amps with a blue band on the bottom portion and the x-over section is in front covered by a plate w/ a small window showing the knobs. A lot of these came out but you can spot the "Good" version from the rest by the thickness of the heatsink. It's way thicker.
    Aug 2018
    Quote Originally Posted by bigpapa View Post
    I don't know but bridging two channels theoretically doubles the power and not the resistance though many amplifiers support variable impedance values. I think it would be best to go back to what the amplifier can support. If it tells 2ohms (bridged) then powering the sub wired in series (producing 8ohms) could eventually result to the amplifier in protection mode.
    Dec 2007
    Quote Originally Posted by doomz View Post
    Only the lowest impedance that the amplifier can handle should be your concern.
    Having a 8ohm load impedance compared to 2ohms will be easier on the amplifier and not the other way around.
CVR12 and x12 mrv-1507
