Han Gang Acoustic Foam or Dynamat?
parang foil. hehehe
check out http://www.dynamat.com/
meron yan sa mga audio shops sa banawe. sa galant i think 2700 is good for 2 front doors pero di ko sure.
Yun parang foil na daynamant is the xtreme dynamat,
black yun regular na dynamat.
Mas maganda ang xtreme dynamat and mas magaan.
ang alam ko yung han gang pang insulation lang. it's made to keep heat enclosed inside the engine at para di humawa sa hood at magbitak pintura. if those are your choices, i'd go for dynamat![]()
there's supposed to be a hangang product for sound insulation.
have not tried it yet.
How do you insulate against road and engine noise?
Put sound deadening to roof, doors, floor, trunk
basically take everything out and install deadening, you can even
install a second layer to have better sound proofing.
How about noise that goes in through wire access points through the firewall and transmission access areas?
Hi!meron yan sa mga audio shops sa banawe. sa galant i think 2700 is good for 2 front doors pero di ko sure. [/B]
I'm not familiar sa Banawe. Do you know any specific audio shop that sells dynamat?
How about Peel & Seal, is it available here also?
Thanks.
