Results 1 to 7 of 7
    Nov 2007
    My Isuzu Sportivo with JVC EXAD head unit with 6 speakers is lacking BASS. I am planning to upgrade my audio set up by adding a subwoofer. I am not after the high-end set-up, I just need to boost the BASS and that will be enough for me already. It seems there is a provision for the 2007 Sportivo to add a subwoofer at the left side at the back, in the 3rd row seat, but I am not quite sure. Has anybody used this already for an upgrade? Thanks for sharing.
    try mo ang self powered sub ng JVC para terno lahat. it is small enough to fit below the front seats. yun lang dont expect a lot from it.
    Nov 2007
    thanks for sharing. How much would it cost to get that JVC sub? Would it be ok if it is located underneath the front seat?
    Nov 2007
    m using a 10'" nbn self powered sub in my sportivo. its located at d back of the third row seat. un nga lng, mejo nabwasan ang cargo space. i also installed a 2way speakers sa front pati tung sa likod pinalitan ko rin, madli kc masira lalo na pag hi ang volume.
    Jun 2007
    sir rey022ph, i think iyung nasa left side is where the air blower is located. i think sir it will depend on your prerefence. it's either you buy a powered sub or you'll get an amp and a sub separately.
    sir try to visit this site, may be it can give you an idea : KOTSEAUDIOCLUB.COM
    Jan 2012
    sir, yung sakin tinanggal ko na yung 3rd row seat nung ngkabit ako ng sub. kasi Kicker L7 15" solo-baric ang ininstall ko. all speakers pnalitan ko din. pero kung sakting sounds lng ang gsto nio, pwd n yung cnabi ni ARB.
    you can try this kind of setup first imho..
    seps, coax, 4channel amp and sound deadening... lalabas na po midbass nyo dyan... in my experience mas maganda ang tunog compared sa amplified sub sa ilalim ng upuan that produces TONG TONG sound instead na boom boom. if bitin pa po kayo sa ganun... instead na mag amplified sub po kayo, you can use yung spare space dun sa left side ng 3rd row and put an 8 or 10 inch sub there., pero kailangan maenclose pa din po yung ng mdf board sa likod ng plastic cover and reinforced din ng mdf sa harap. ganyan po ginawa namin sa sportage last time.
Isuzu Sportivo Subwoofer set-up
