Results 1 to 10 of 10
    i read on 2 different threads na meron available windshield antenna (sticker type) para sa radio. meron ba yung pwede sa tv? papabili kasi ng lcd tv si misis para daw nakakanuod siya pag inabutan kami ng gabi sa daan. kaso ang problem e alam ko mahina reception ng tv na ganito. kahit ibang type basta ok reception. meron kaya? need booster?
    Jan 2003
    ive seen a plasma car tv antenna. its installed at the rear windsheild. looks ok. about the reception, it depends on your location. sometimes malinaw and sometimes hindi.
    saan kaya available?
    Jan 2003
    try nyo po sa ginza, banawe.
    ok thanks pards. punta ako dun pag uwi ko
    Jan 2003
    anong hitsura ng antenna? rinig ba ang sounds?
    Jan 2003
    the antenna is mounted at the rear windsheild, thin black metal kasing haba ng deffoger.
    Oct 2004
    I have one. Two pcs black thin metal with tape as fastener (400 bucks bili ko sa SM). The reception is not that good (depends sa place). Nung na try ko una pag sa labas ng van malakas reception pero nung kinabit ko na sa loob lumabo na. I guess the best pa rin yung mga kinakabit externally
    Jan 2003
    is the sound reception that clear? or are you guys referring to the video?
    i heard that even what kind of antenna you get, reception will never be clear enough to watch comfortable, is this true? do you know anyone who gets good reception and what brand? set-up?
meron ba tv windshield antenna?
