Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Mar 2015
    Normal ba ung 28 volume maximum pag sumobra nawawala bass tapos bumabalik parang kinakapos kuryente? Any suggestions? Ryan Audio Wirings?
    hindi normal..... check the connections between the amps and the subs.
    Mar 2015
    Quote Originally Posted by 1D4LV View Post
    I've checked sir, connected naman po properly, fyi naka (LOUD ON) po pala yung headunit. Any more suggestions sir?
    Jun 2006
    Have you checked if the amp is going to "protect" mode? That could be the reason why it is cutting off.
    Mar 2015
    Nope sir, it doesn't even get hot. Parang kinakapos siya ng hininga kumbaga. 12" subwoofer with jbl mono amp. + Big 3 Upgrade
    Feb 2011
    you can try to turn off Loud coz that increases the db from low to mid FR. so if you have 28 as your peak volume, it tries to exert more effort to do so. also, there can be a possibility aside from those mentioned that either your sub driver is clipping or kinukulang ng current yung daloy sa amp mo. the latter can be solved by adding an extra battery or a capacitor.
    Mar 2015
    Quote Originally Posted by sientobente View Post
    I do have a 1.2 farad cap, extra battery requires bigger alternator right? Does my capacitor adds stress to the sub kase dami nag suggest wag na dw ako mag cap
    Dec 2007
    This is assuming you have a ported enclosure....If the amplifier is not going on protect mode or not over heating then your problem might be on the design of your subwoofer enclosure. The sub might be unloading (loosing control) when it is hitting the bass notes below the port tuning frequency at high volume. The culprit would be the wrong measurement of the port.
    What you can do for now is to set the cut off frequency to a higher value. Saan ba naka set ang cut off frequency sa low pass filter nang amplifier?
    Mar 2015
    Quote Originally Posted by markygy View Post
    Sir, i don't have any idea po sir sa sinasabi niyo, sorry I only have limited knowledge about sa parts and 'term' nila. I'll have it checked po sa isang audio shop malapit samin. If you can suggest ano po pwede ko ipa-check sakanila para malinaw. Thankyou po sir!
    Quote Originally Posted by Red Paul View Post
    Add ko lang baka sakaling makatulong... check yung polarity.
How to increase my maximum volume since bass is cutting out
