Results 1 to 10 of 11
- Mar 2015
- 26
March 24th, 2015 02:33 PM #1
March 24th, 2015 02:52 PM #2
Have you checked if the amp is going to "protect" mode? That could be the reason why it is cutting off.
- Mar 2015
- 26
March 24th, 2015 06:36 PM #3Nope sir, it doesn't even get hot. Parang kinakapos siya ng hininga kumbaga. 12" subwoofer with jbl mono amp. + Big 3 Upgrade
March 25th, 2015 02:17 AM #4
you can try to turn off Loud coz that increases the db from low to mid FR. so if you have 28 as your peak volume, it tries to exert more effort to do so. also, there can be a possibility aside from those mentioned that either your sub driver is clipping or kinukulang ng current yung daloy sa amp mo. the latter can be solved by adding an extra battery or a capacitor.
- Mar 2015
- 26
March 25th, 2015 02:35 PM #5
March 25th, 2015 03:53 PM #6
This is assuming you have a ported enclosure....If the amplifier is not going on protect mode or not over heating then your problem might be on the design of your subwoofer enclosure. The sub might be unloading (loosing control) when it is hitting the bass notes below the port tuning frequency at high volume. The culprit would be the wrong measurement of the port.
What you can do for now is to set the cut off frequency to a higher value. Saan ba naka set ang cut off frequency sa low pass filter nang amplifier?
- Mar 2015
- 26
March 26th, 2015 03:11 PM #7Sir, i don't have any idea po sir sa sinasabi niyo, sorry I only have limited knowledge about sa parts and 'term' nila. I'll have it checked po sa isang audio shop malapit samin. If you can suggest ano po pwede ko ipa-check sakanila para malinaw. Thankyou po sir!
Are they on track to surpass last year's sales?
Car Sales Data (2025)
