Results 1 to 6 of 6
    Aug 2010
    balak ko sana mag add ng isa pang amp para sa sound system ko,kaso ung h.u ko.isa lang ang pre out niya.pano ko kaya maicoconnect ung sub sa hu na naka connect sa isang ampli?at yung mga pang boses ko eh maligay din sa isang amp?any idea guys?
    Connect the pre-out to your sub amp, then use a line output converter to connect the speaker outputs on your HU to the inputs on your 4-channel amp for your seps.
    Jan 2008
    a simple Y-connector (1 female to 2 male connector) will do the job... you get the same source for both amps
    Jan 2009
    Avoid using an LOC.
    Here's one design consideration. Use a monoblock (single-channel amp) for the 2nd amp to power the sub. This amp should have stereo RCA pass-thru.
    HU
    (RCA out)
    (RCA in)
    monoblock ---> sub
    (RCA out/pass-thru)
    (RCA in)
    2-ch amp ---> seps
    May 2010
    Quote Originally Posted by chilimint19 View Post
    try this....
    bumili ka ng dalawang ganito sir
    tapos yan ang ikabit mo sa HU mo para 4channel ang labas hehehe
    bale isang ganyan para sa left..at isang ganyan para sa right
    split type kasi yan
    *heaven rio's boss pano naman i split yung power nya!
how to use 2 amps
