1. Ano mga options kung saan pwede i install ang crossover? why?
2. For budget set up, kailangan ba branded wires or pwede na yung generic? what size ang ginagamit sa LnC application?
3. Kailangan ba talaga yung big 3 upgrade kahit budget/entry level lang ang set up?
A cross-over is what seperates the treble signals out of the positive cable coming from the amp, and sends them to either the midrange driver, if the speakers have one, or the tweeter. If there IS a mid-range driver, then another 'cross-over' capacitor of a different value of mH (milli-Humphrys') is used to leave the mid-range part of the signal with the mid-range driver, and send the high treble notes to the tweeter.
If you have bought good quality 6x9's, they will have these in the speakers already.
If you are not picky any car stereo wire will do for your cross-over but no smaller than 14 guage(12 guage is ideal).
Forget about Big 3. If you are in serious competition of sounds than can awaken the long time dead people, then you should, if not....leave it as is.
una crossover yan po ang nag hihiwalay ng signals from your source through the amplifier to your output device (speakers)
pangalawa if your planning to go Loud and Clear go get straight to guage 4 wires para more current ang dadaloy generic is good but branded once like firland audio is better.. konte lang naman difference nila sa price dun ka na sa branded.
pangatlo big 3 aka grounding kits are important lalo na sa mga matataas ang wattage ng system or even low wattage once... why? kasi po it helps po sa charging system ng sasakyan mo if you leave it stock tapos mataas system mo aside sa maaring masira ang battery mo pwede ring masira ang alternator mo.. not to mention yung amlifiers and speakers.. why ule? because you amplifier has a required minimum voltage to pass through it so if you hit below it like lets say 11v or 10v kiss your amplifier goodbye and dahil mababa ang boltahe na dumadaloy sa amplifier dirty signals na binabato nun sa speakers mo... you know what will happen next.. thats right byebye speakers.
