Results 1 to 7 of 7
- Aug 2007
- 675
August 15th, 2008 12:58 PM #1Hi, does anyone know where I can get a low-cost FM signal booster?
This device is attached between the antenna and Car FM receiver to "Boost" the signal of the antenna and make FM stations with weak signals stronger.
In the US, Radio shack used to sell this for around $10. Here in RP, I havent seen anyone sell it, although Ive seen it attached to a home radio system in tagaytay.
August 16th, 2008 02:31 AM #2
Try the shops in Raon.
If you can't find one, a TV signal booster will do ... the FM broadcast band is within the Hi and Lo limits of the VHF-TV band.
- Aug 2007
- 675
August 18th, 2008 11:13 AM #3
- Aug 2008
- 44
September 13th, 2008 06:49 AM #4
- Jun 2008
- 11
September 22nd, 2008 09:10 PM #5Hindi kaya ma-amplify din yung noise signal since pinapalakas mo yung buong broadcast band?
September 23rd, 2008 03:58 AM #6
If you're talking about noise such as atmospheric noise ... an amplifier that can boost a signal 10 times doesn't mean it also boosts noise by 10 times. A good amplifier keeps the noise down when amplifying signals, at a lesser level depending on the amplifier's noise factor.
September 23rd, 2008 08:14 AM #7
i have one in my system.. had i for almost 10 years. i bought one in order to minimize my use of the antenna, power antenna of my maxima is expensive! but sa provincial, medyo sagap yung mga major stations even if nasa palayan city ako or dulo ng nlex(w/the ant. rod at full length...)
para kahit retacted lang siya makakasagap pa ng maayos on all range ng FM, but on the AM, no use to ha....
sa concord or mg infiniti or sa suki mong banawe shop meron. di ko na matandaan ang presyo,e...
ung (+)-power attached mo sa acc-on power ng line to prevent battery discharge ka..on siya when you turn the key to acc-on position...
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
