Results 1 to 4 of 4
    Oct 2005
    need help po guys.. iv been using for a while now an active subwoofer connected through the preout of my head unit. It has been working great for a year then when removed it for cleaning tapos binalik ko. Biglang may noise na cya.. u could hear it comming out of the subs when u press on the accelerator or when the cd is reading. please advise what i could do?
    thanks..
    Feb 2005
    Check your wiring. The car came with an amp that powered 2 6x9's at the rear. It had the same issues as you described. I replaced then soldered a new set of rca jacks to the wires that connected the 6x9's to the amp.
    Oct 2005
    thanks Zman! Will be trying that.. :D
    baka alternator whine yan. just also check your grounding points.
Acceleration noise sa SubWoofers
