Results 1 to 9 of 9
    May 2013
    Sir help naman ride ko is hilux 3.0
    Nawala ang sound mapa fm cd o bluetooth
    Pero may beeb sound pag press ang botton
    Pag on/off maraming beses minsan nagkakasound pero di naman ma adjust ang volume "mute o zero volume" gumagana
    Na reset ko na by option and by the small button katabi ng memory card!
    Ganun parin ano kaya solution?
    Thanks mga ka stikot
    Quote Originally Posted by athrun View Post
    Maybe your wiring leading to your speakers got loose?
    If it cant be done by soft reset then do the hard reset by simply removing the fuse. Or if youre lazy crawling under the dash, pop the hood, remove bat negative terminal, press the brakes, switch ignition key, reconnect battery.
    note. your clock settings will be reset and fuel learning will default.
    May 2013
    Thanks sir sa fast reply subukan ko muna yun hard reset diy lang kaya ko tong gawin
    Medyo mahirap na pag wiring ang nag loose kelangan na ng nakakaintindi sa mga wires
    Report na lang ako bukas!
    Thanks again sir K.I.L.L and sir 12vdc
    May 2013
    Gud morning mga ka tsikot!
    Katatapos ko lang mag hard reset wala paring epek, 8 month pa lang to me sopak na agad
    Any advise uli? Thanks
    Under warranty pa pala. Review mo mabuti ang manual, else dalhin mo sa dealer for warranty claim.
    Baka stucked keys yan or kung confident ka in your DIY skills na hindi ma notice ng dealer, remove the HU bracket and check mo connectors sa likod by tangal-kabit to see if may loose nga. You will need M10 socket at philips screwdriver. Kung wala pa rin, ipaubaya mo na sa dealer at baka mavoid warranty kung bubuksan mo headunit.
    May 2013
    Dapat bang na erase mga station sa radio pagkatapos ma hard reset di kasi na erase. Pero tagal na naka disconect ang battery after trying to start iniwan ko pang naka on susi!
    Pa check na lang namin sa auto service na malapit, baka void na ang waranty. nong 10k mark di na casa nag change oil malayo sa casa loc. Ko
    Thanks uli sir 12vdc
    Dapat ma-erase kung may na i-program ka. Pero baka ang nakikita mo ay yung default pre-set stations.
    I'm not familiar with newer units usually Clarion and Fujitsu OEM gamit at bihira yung may internal volatile ram battery. Nasa manual ng Headunit kung may internal bat. Baka hindi matagal ang pag reset, hindi nadischarge capacitor ng HU. Try to press the ON button while bat disconnected. Kung mababaklas mo ang HU remove the connectors and trace the + fuse wire then short it to the chassis para madischarge.
    Nag skip ka sa 10k PMS pero not in anyway related ang malfunctioning headunit sa PMS(wala sa service checklist), kaya pwede mo i-contest ang warranty claim.
    May 2013
    Sir habang naka disconect battery terminal try ko power on ang HU start makina' ilaw power lock para sigurado na madischarge! So baka maaari na me internal ram
    Suko na ko kaya sa auto shop or kung makakapunta sa casa! bahala na anyway sir many thanks sa advice!
no sound!
