Results 1 to 4 of 4
- Nov 2002
- 103
April 25th, 2005 11:28 PM #1Hi! kanina nasa roadstar fort ako, nagset up ako sounds ko. pero may doubts ako sa ginawa nila. from battery to first fuse (near battery) to second fuse (near amp in trunk)= gauge 4 na wire ang ginamit. pero biglang naubusan na ng stock. so from second fuse to amp biglang naging gauge 8 wire na. ok lang ba to? what are the negative effects of this if there are any? oh and btw, amp ko is 600W 4 channel blaupunkt powering one pair of seps and 400w blaupunkt sub.
- Oct 2004
- 19
April 25th, 2005 11:32 PM #2ok lang yun pare.theoretically, parang nag bo bottle neck ang current, but i dont think it will have any problems with it.ganun din set up ko dati for 4 years, nothing happenned naman.
April 27th, 2005 12:22 AM #4
ayus ah masyado sigurista yung setuo hehe. Kailangan pa ba talaga nung second fuse for the amp? I think ok na yun ginline fuse malapit sa battery eh.
Usuall another fused distribution block us used pag dalawa amp mo. taka lang ako since one amp lang bakit ginamitan ulit ng 2nd fuse?
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
