Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Apr 2005
    My current Clarion HU has no MP3-playback capability, so i'm chosing between these two as replacement. DEH-P7750MP is around P13K and CDA-9830 is around P14K...depending on the shop, but basically di sila nagkakalayo ng presyo. I'm just going to replace my headunit, using stock speakers. In the future i plan on getting a good amp and a sub, and upgrade the stock speakers, for SQL setup. So it is important that the HU is ready to take on my future upgrades.
    I really need more input on their differences(from your experiences), aside from the voltage output(2v vs 4v), i-pod compatibility, power output, displays(OEL, etc). Which is quicker reading MP3s & CDRW? Parts/service availability? And any other small details you don't usually see from the brochures but rather learn/experience through actual usage.
    Also, if you think there are better choices besides the two, in that price range(2nd-hand/slightly used included), please let me know as well.
    Many thanks!
    i would opt for the 9830. .
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Oct 2003
    Quote Originally Posted by caloyski5
    me too. bias ako sa 9830 because i am using one right now. compared to pioneer hu of my friends (same price range) mas lamang ang alpine sa SQ. feature wise mas lamang ang pioneer esp with their display. its up to u if u prioritize the looks or the sound.
    jas my dos sentimos
    Apr 2005
    thanks caloyski & wingman. i'm actually leaning on the 9830 as well. next higher model kasi for the 7750 is the 8600 series at sobrang layo ng price na. BUT..i'll probably save up a bit to get the 9833 instead. I read it has better built-in x-over feature than the 9830/31. Plus reviews from Crutchfield.com are amazing!
    Apr 2005
    Quote Originally Posted by Boy Torotot
    9833 is out of stock but assuming i can source a brandnew unit from abroad, which would you guys recommend: Alpine CDA-9833 or Pioneer DEH-8650MP? The pioneer, i can get right away from banawe.
    Oct 2003
    go for it man. balitaan mo na lang kami. pic pala sa set up mo pagnatapos
    Apr 2005
    yup.. pero isa-isa lang muna men...HU muna...then unti-unti yong amp/sub/speakers... baka makahalata ang dept. of budget sa bahay...
    basta dapat before the long vacation nakabit na, para di naman boring byahe papuntang probinsya
  8. #8
    up!
    i have the same dilemma. would appreciate all inputs
    additional questions:
    1. is it true that it is difficult to see the display in the 9830 during daylight? reviews at crutchfield.com were almost unanimous in this aspect.
    2. is it true that alpines are less user friendly than pioneer HUs?
    Quote Originally Posted by April_Ryan
    up!
    1. hmmm...personally havent seen the display of the 9830 ..pero that would depend on a lot of things. . .where the HU is located and kung may tint yung car/windshield.
    kung sa bandang lower area ng center console, hindi siguro mahirap makita. . pero kung sa bandang taas, baka. .
    2. i personally found it more difficult to use the higher end alpines (9835, 7998) kesa mga 9827. .my ex-HU. .sobrang dali gamitin. sa pioneer, mas direct to the point nga. . ...i would say its true.
    Apr 2005
    up!
    Hey April_Ryan! I have a reply on your post in KAC. Anyway, my 2 cents... from what i've read and learned so far(sorry no actual experience), for the price range of the 9830, i'd get the Alpine any day. If i can get hold of a 9833, much better. The only closer match to the 9830 from Pioneer is the 7750MP(P13+K), then ang susunod na is the 8650MP(P21+K), too far na. The problem is these Alpines that we're considering are currently out of stock AFAIK except for 9827.
    Do you know of any shop that have these Alpines in stock(9830/31/33)? Otherwise, i'll post my next choice...
    And btw, the display in daylight wouldn't stop me from picking up the 9830...
  11. #11
    You got PM re shops, but you're right, 9827 lang ang readily available. i also checked out reviews of the 9833, glowing!
    Oct 2003
    up!
    1. depende kung saan naka mount ang hu mo. sa'kin nasa upper part ng dash, so wala akong prob sa display viewing. xuv pala ang ride ko.
    2. sanayan lang yan. pag galing pioneer ka mahirap ang alpine???. ako pio dati hu ko pero dali lang rin matutunan ang alpine basta mahilig kalang kumalikot.
    up!
    for me, yes it is difficult to see. Our car is a civic ek, no tints, the hu is positioned on the 'high' side of the dashbard. When its sunny, i can't see the display. But it doesn't really bother me that much. i even set the display to auto-off to save power (according to manual it improves clarity daw).
    I have no experience with pioneer hu's...sorry.
    Jun 2004
    try nyo sa perfect circle sa banawe...mura lang dun..9831 13,300 lng bigay sakin dati..
    Oct 2003
    if you're going to source it out sa states, you could get a alpine 9847 for only 200USD converted here its only 10K.
    Apr 2005
    yep.. ganda pag makapag-source sa states, dami pa choices.
  17. #17
    called up C3 yesterday. meron silang 9830, in case you're interested. ako, i changed my mind na. will go with a lower end model na. good luck with your search.
    Apr 2005
    waaaatt? meron na ang C3 ng 9830? deym...kakatanong ko lang last week, wala na daw stock tapos bigla nagkaroon i'm going for the 8650 pa naman. sige po, will give them a call. thanks!
    Feb 2003
    parang replay to ng one or two threads sa ibang forums dati...
    i used to have a 7700 (US ver. ng 7750), grabbed it as soon as it came out sa US...
    was quite happy with it, pogi yung OEL though not colored.
    then i bought the 9831 and happily sold the 7700...
    why, bec. on the same setup it definitely sounded better, largely bec. of the 4v pre-outs.
    the time correction, bass focus, and 4-band eq were quite useful too.
    Feb 2005
    ano pong number ng C3? thanks.
Pioneer DEH-P7750MP or Alpine CDA-9830?
