Results 1 to 11 of 11
    i really can't find the reason pero bigla na lang namamatay at nabubuhay radio ko. wierd kasi i can't seem to recreate it. minsan nangyayari sya pagnalulubak. minsan naman pagsimpleng umaarangkada. one time bumabagal lang ako ng mahinahon.
    i've check the connection sa radio and yung splicing ng wires, ok naman. saan pa kaya pwedeng problem?
    another thing. yung hu ko kenwood na may usb. nung una ok siya. ngayon biglang may static na matinis kapag naka usb mode. pero kung tuner, ok lang. could this mean the hu is defective? or connected pa rin sa power issue?
    TIA!
    Sensitive ba talaga ang kenwood? Pati yung sakin noon namamatay bigla. Ang ginawa ko, pinalitan ko lang ng fuse, then wala na.
    Quote Originally Posted by beni23 View Post
    hehe ganun ba? ano sir pinalitan mong fuse, yung sa fusebox or sa unit mismo?
    May 2010
    sir matibay naman ang kenwood kasi yung samin 3years na di pa naman siya nag mamalfunction,
    Jan 2009
    try ninyo mag lagay ng grounding kit. my experience was when i installed a sub woofer the whole thing (car engine, sound, air-con) would go dead after I do a startup.
    daming recommendation from different shops. the one i followed was the install a grounding kit recommendation. ayun ok na ok na. cost - P900.00 including labor.
    btw mine is an older vehicle. 1996. usually effective na mga grounding kits pag luma. not so with newer cars and stock cars.
    1998 sasakyan ko. so pasok sa 'lumang cars' :D
    sige, tanong ako sa malapit sa amin about grounding kits.
    nagtry pala ako kanina na tanggalin at alog alugin pati wiring para mareplicate yung pagpatay niya. 'unfortunately', di sya nagloko. so meaning walang loose power line at least sa area of the radio. frustrating kasi minsan nagmiminor lang sa smooth surface namatay siya tapos nag-on uli after a few seconds.
    Quote Originally Posted by coiter View Post
    Sa unit mismo sir. Usually sa likod lang yun ng unit.
    i think i found the reason sa pag on/off niya! maluwag lang yung battery terminal :| sinikapan ko na and so far, naka 2 trips na ko di pa bumalik yung problem! sana tuloy tuloy na
    problem ko na lang yung static pag naka CD or USB ako. just noticed kanina na left side lang ang nagkakaganun. ano naman kaya issue nito?
    thanks nga pala sa suggestions!
    Dec 2007
    sa akin din biglang namamatay pero isang channel lang (minsan kapag nalulubak/simpleng andar/simpleng stop).
    i tried swithcing the RCA cable sa amplifier ko, yung kabilang side naman ang namamatay. hindi ko tuloy alam kung amp yung may problem...
    pero nabubuhay ulit kapag nilakasan ko yung stereo ko (max volume).
biglang namamatay
