Tama po ba itong gagawin ko?
for dual-fans
note: WALA pong "87A" sa Bosch Relay na nakalagay...
for dual-fans
pang rekta po yung connection nyo masmaganda kung one relay per fan para di kapusin, singitan mo na din ng fuse sa positive line closest to the bat.
yes. but aside from one relay per fan and no fuse issue. is my connection alright?
OK naman po yung connections...
Yung 87A po ay sa mga normally closed na relay (normally naka-ON yung contacts - then when coils are powered, contacts will be off)...
HTH...
salamat po sa inyo.I guess bili pa ko ng isa. akala ko okey na yung may dalawang 87-only slots para sa dalawang fans.
Huh, Huh, Huh...
Tulong po!
hindi gumana yung connection ko...
gumana lang siya kung gawin ko ang #86 from negative to positive. peru duda ako kung tama ito...
tulong po, ano pa ang mas maganda na connection?
Yung 86 ata dapat papuntang ground din to complete the circuit. I might be wrong so wait for more feedback
Don't forget the fuse/s between your batt positive and relay![]()
hehe... mali pala yung source ng switch ko... ang dilim na kasi eh... ok na po.
maraming salamat po.![]()
Tapos na pala yung project mo, so this may well be moot.
Most relays (well, at least those that I've seen) are rated at 30 amps. If the total current draw of your 2 fans is less than this, then as long as you use the correct gauge wire (read: thick enough) for the connections from battery to the "30" terminal and from "87" to the fans, you'll be ok with just 1 relay.
rion > saan mo nilagay yang 2 fans? for your radiator/ clutch-fan removal and replacement with electric fans?
pin 86 should be connected to ground since pi 85 is already connected to positive...![]()
thanks for the Tip. may nakita nga akong website that says this particular relay is enough with two fans. link but I found a extra relay sa garage so dalawa relay na ginamit ko.
it's just a re-wiring on the front a/c radiator with dual fans. including re-wiring of the another fan on the rear secondary a/c radiator.
yung source ng pin 86 that should be negative (first pic) becomes positive when switched on. and my pin 85 line was not intended for a (+)switching line. kaya problema...
peru tapos na po wiring ko. pwede na ba ito? ang hirap na kasi ulitin pa yung switch ko to make it a negative switching type... and my source with the thermostat trigger line is positive kasi eh...
ok.. hehehe..pasabit pwede?
kung in an event na switch on mo-pumipitik ang relay, pero yung equipment di nag-function, maari bang sign yun ng busted relay?
headlight ko kasi ganun,e.... siguro nga relay prob lang..bumili na ako ng replacement..mahal ang original toyota headlight relay,e...
repairable ba mga relay na ganito?
