Normal ba ung 28 volume maximum pag sumobra nawawala bass tapos bumabalik parang kinakapos kuryente? Any suggestions? Ryan Audio Wirings?
Have you checked if the amp is going to "protect" mode? That could be the reason why it is cutting off.
Nope sir, it doesn't even get hot. Parang kinakapos siya ng hininga kumbaga. 12" subwoofer with jbl mono amp. + Big 3 Upgrade
you can try to turn off Loud coz that increases the db from low to mid FR. so if you have 28 as your peak volume, it tries to exert more effort to do so. also, there can be a possibility aside from those mentioned that either your sub driver is clipping or kinukulang ng current yung daloy sa amp mo. the latter can be solved by adding an extra battery or a capacitor.
