Results 1 to 13 of 13
    Jan 1970
    Han Gang Acoustic Foam or Dynamat?
    i can only speak for dynamat..they are very good.
    great value.
    Jan 1970
    Who sells or installs dynamat?
    Jan 1970
    ano itsura ng dynamat.... tnx
    Mar 2003
    parang foil. hehehe
    check out http://www.dynamat.com/
    meron yan sa mga audio shops sa banawe. sa galant i think 2700 is good for 2 front doors pero di ko sure.
    Jul 2003
    Yun parang foil na daynamant is the xtreme dynamat,
    black yun regular na dynamat.
    Mas maganda ang xtreme dynamat and mas magaan.
    flashband
    ang alam ko yung han gang pang insulation lang. it's made to keep heat enclosed inside the engine at para di humawa sa hood at magbitak pintura. if those are your choices, i'd go for dynamat
    Jan 1970
    How do you insulate against road and engine noise?
    Apr 2003
    there's supposed to be a hangang product for sound insulation.
    have not tried it yet.
    Jul 2003
    Put sound deadening to roof, doors, floor, trunk
    basically take everything out and install deadening, you can even
    install a second layer to have better sound proofing.
    Jan 1970
    How about noise that goes in through wire access points through the firewall and transmission access areas?
    May 2004
    meron yan sa mga audio shops sa banawe. sa galant i think 2700 is good for 2 front doors pero di ko sure. [/B]
    Hi!
    I'm not familiar sa Banawe. Do you know any specific audio shop that sells dynamat?
    How about Peel & Seal, is it available here also?
    Thanks.
What is the better for sound insulation?
