Results 1 to 18 of 18
    Jun 2003
    are 6x9s good for rear fills?
    or should i go for a subwoofer n box?
    im only after the sound quality...
    will putting coaxials be sufficient?
    or should i get separates?
    and lastly totoo ba ang compliance na sinasabi? lets say you wont put amplifiers and head unit lang and speakers pioneer head unit pioneer speakers? so on....
    will this sound better? or pwede naman halo halo
    6 x 9's are good solutions for the price if you're on a really small budget. otherwise i don't recommend them for your goals.
    they won't have the bass response i think you're looking for - definitely not like a sub of any size (but then again, they don't take up any trunk space)
    if your goal is sound quality, i'd recommend at least coaxials for rear fill together with the sub...make sure your fronts are a high quality separate set because that's the most crucial area.
    finally, that 'one brand' mentality is bs in my opinion...so many good parts out there from different companies that work just fine or even better than just one manufacturer...plus the very best speaker and amp manufacturers don't make head units anyway.
    agree!
    most new components can be mixed and properly matched, don't believe that you "must" have just one brand of equipment.
    now, it would be up to you as to what to install. yes, you would be saving space with 6x9s on the rear deck, but sound will not be as good as if with a sub. i'd recommend getting seps up front, then a sub in the trunk. most new subs for SQ applications need only very little boxes, and you can have them designed so they can be pulled out.
    Rear fill lang ba? Huwag na! hehehe. Ako walang rear fill. Puro sa TARGA TX-420 seps lang galing ang mids at highs. Ok din naman ang sound kahit nasa likod ka.
    Subwoofer na lang ang nasa likod ng sa akin. Hindi naman location-specific ang subs, eh.
    Dati uso ang may apat na JBL 6x9s sa likod hehehe :D
    nung nabili ko yung hatch para kay misis
    may 2 jbl 6x9 and 2 8 incher na sub
    tinanggal ko agad yung set up na yun...
    Jun 2003
    bakit?
    dito na yan...at nang magawang pera!herhehrehr
    Nilipat ata ni kim sa Strada. Loko loko yan, eh. hehehe.
    nabenta ko na hahaha
    pinalitan ko ng coaxials
    pero wala na rin yung hatchback eh he..he
    6x9's are good for low budget set-ups.....balance ang sound......pero not to be intended for high volume operations.....:D
    can my stock clarion HU with a tape deck power a 6x9 guys? and a pair of seps infront? La kasi ako money for a new HU eh.. :bald:
    Kaya naman. Ginawa ko na dati.
    thanks otep!:D ano ba mura brand na 6x9 pala? and seps? yung ok naman performance.:bald:
    you should audition the speakers na muna before you decide buying a pair... what sounds good to someone might not sound good to another.
    exactly!!! :D
    a targa seps infront and a pioneer 6x9 at the back. mga how much kaya guys?:beard:
are 6x9s good?
