Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jan 1970
    some cars have this meter which gives an estimate of the consumption (km/l) in realtime. I think even the range can also be computed.
    Has anybody tinkered with their ECU's? Maybe we can tap some signals there to come up with a gage that will provide an immediate feedback on the car's mileage.
    I was thinking a simple electronic gage (or a color-coded bar graph?) attached to the O2 sensor or pressure in the manifold?
    Is there an off-the-shelf product available?
    I figure changing driving habits can be significant but a feedback mechanism would help accelerate the learning process under various conditions (accelerating, cruising, braking, up/downhill, idle, w/ or w/o aircon, etc..). We can expect the price of gasoline to go up pa rin in the near future so I need all the help I can get.
    Thanks...
    Most European cars have a 'fuel economy' gauge. Not that it is very accurate. I'm not sure how those things work.
    On our W124, it's an analog gauge clustered with the fuel, temp, and oil dials.
    poops,
    there is an off-the-shelf product that will show you INDIRECTLY fuel consumption in real time ... the vacuum gauge
    install a vacuum gauge, not so expensive, then drive in such a way that the vacuum level is kept at higher reading at most times ... you'll find that fuel economy improves
    you'll also find that keeping vacuum at high level necessitates that you must be easy on the gas pedal
    if you want kinda high-tech stuff, the MAP (Manifold Absolute Pressure) sensor on modern engines sends out a signal proportional to the vacuum level ... this signal can be used to display vacuum into an electronic LED bargraph display ... i think i've seen such electronic vacuum gauge in the market (sa concorde yata), but i'm not sure if it uses the MAP signal or the usual vacuum line (it which case, it must be using some kind of pressure transducer for electronic display conversion)
    i once found in the net a schematic for such display, built one, made some modifications to make it compatible with my civic MAP sensor signal and it worked ... which means it is possible to diy such project if you are electronically inclined and the whole project will not cost more than P1k
    if your car has the ODB II port...
    www.scanguage.com
    ok yung scangauge a, kaso ang mahal, hehehe
    sir kinyo, pede po ba makita circuit diagram nung nung ginawa nyo? ok na project to
    Jan 1970
    thanks guys...
    I was thinking of tapping into the ECU wiring for the MAP or something similar. Since I'm also electronically inclined, a simple opamp to condition/calibrate the signal before feeding it to a color coded display driven by an LM3914 (National) for linear or LM395 if logarithmic.
    I just don't know the wiring harness of my Altis (1.6E '04 M/T) and if the input impedance to most op-amp's won't affect the ECU operations.
    Salamat...should be less than 1K nga. More the aesthetics para matched sa dash.
    Jan 1970
    thanks guys...
    I was thinking of tapping into the ECU wiring for the MAP or something similar. Since I'm also electronically inclined, a simple opamp to condition/calibrate the signal before feeding it to a color coded display driven by an LM3914 (National) for linear or LM3915 if logarithmic.
    found this one sa net, parang ok sya ...
    http://www.pelicanparts.com/techarti...el_monitor.htm
    Quote Originally Posted by endlessgwing
    eto o ..
    i don't have the original circuit i found in the net ... what i have shown is the actual circuit of my final prototype ... iirc, my modifications were: i used 5-volt power, added diode and capacitor at the input, used 100k trimpot at the input to be able to calibrate the display while offering high-impedance to sensor's output ... note that the 5-volt regulator is not shown but it is part of the circuit, including associated capacitors for stability ... using 5-volt power keeps the LM3914 chip run cooler in bar mode
    Jan 1970
    You may have to add a limting resistor for each of the LED to keep the current to say 20mA. I usually use 220 ohms 1/4 watt depending on the LED. The sink rating I think is somehow limited.
    The circuit from endlessgwing uses a 3915 for logarithmic. My guess the sensor is likewise log based.
    and here is the MAP sensor output characteristics
    note that high vacuum is on the left side of the plot where the output is nearly 3 volts ... so the bargraph should display full scale (all LED's lit) at this condition ... since the LM3914 is set for 1.25 volt full-scale at its input pin 5, you could expect the trimpot to be positioned just around the middle for proper calibration
    in my car, during idle, 6-7 LED's are lit ... all LED's lit up during deceleration ... no LED lits up when gas pedal is pressed hard ... i've used rectangular LEDs with red for 1&2, yellow for 3 to 6, and green for 7 to 10
    good luck!
    thanks sir kinyo! makaadaan nga sa deeco or alexan this weekend, hehe
    Sep 2004
    OT: those diagram reminded me of my pre-engineering days in college. wheew.
    eto datasheet ng LM3914 sa mga may kelangan:
    http://www.national.com/ds.cgi/LM/LM3914.pdf
    para naman sa LM3915
    http://www.national.com/ds.cgi/LM/LM3915.pdf
    Quote Originally Posted by Poops
    yep, hindi linear yung output nung sensor dun sa site na nakita ko, dun sa figure 1 andun yung graph nung output nung sensor (voltage vs excess air factor)
    The datasheet shows why resistors are not needed for the LEDs.
    Jan 1970
    Cool..no limiting resistors. Mindset ko kasi before was with thos LS245 drivers.
    Thanks. BTW, what 5V regulator are you planning on using (i.e. with a 12VDC input voltage)?
    The one that comes in TO-220 package. It should work without heatsink.
    May 2004
    sir kinyo, nice project... patanong na rin... san ba MAP sensor ng civic? wala akong alam dun e... pwede rin bang makita yung led display mo? (yung finish product) tia!
    jepoy ... hirap akong sagutin ang tanong mo kasi nahihilo ako sa avatar mo!
    kunan ko muna ng pics yung mga gusto mo makita ... kapag nawala ang hilo ko bukas ... btw my project is not a finished product, when i saw that my prototype worked, had some fun watching the the display while driving, i didn't have the time to finally install it permanently so i shelved it ... i was happy enough that it worked
ECU signals for mileage indicator?
