check out AutoLine sa estrella st. mkti nung bumili ako dati ng 7450 mas mura sila ng kaunti kesa sa ilang shops sa banawe, bka mas mura sa kanila yung 7550
i'n now planning to change my stock clarion to pioneer 7550. lipat ko yung 2din clarion sa crv. nasira na yung stock kenwood ng crv and will cost P14T to have it repaired!
Got na 7550 in one of the stores in the Makati autocycle.
Initial asking price was Php15,200 pero managed to bring it down to Php14,900 (no install).
It helps if you can do your own install para mas malaki ang matawad mo.
HTH!
Gian
Boybi,
Autocycle is what they generally call the entire place kasi puro mga accessory stores na tabi-tabi. Its along Malugay street, which is ka-parallel ng Buendia near the railroad tracks na. HTH!
DEH-P7550MP
In-Dash CD Tuner with MCD Control and MP3 + WMA Playback
CD FEATURES
Latest S-10 Mechanism
CD-R and CD-RW Compatible
1-Bit D/A Converter, 8fs Digital Filter
MP3 File Playback from CD-R/RW
ID3 Tag Support for MP3
WMA File Playback from CD-R/RW
Disc Title Memory (48-disc, in-dash)
CD Text with Title Scroll
Track Scan
Pause, Repeat, Random Play
8cm Disc Direct Loading
Track / Manual Search
SUPERTUNER FEATURES
Supertuner IIID with Digital Processing
Provision for upgrade to DAB (Digital Audio Broadcasting)
Automatic Seek (Up / Down)
24-station 6 preset buttons
18 FM and 6 AM presets
BSM (Best Stations Memory)
Selectable Local / DX
Selectable Local Seek Sensitivity
9kHz / 10kHz AM switching
MULTIPLAY CD CONTROL FEATURES
CD Text Display with Title Scroll
ITS (Instant Track Selection)
Disc Title Memory
Disc List function
Track & Disc Scan
Repeat Play (Track/Disc/Mag)
CD Pause
Random Play (Disc / Magazine)
Digital Compression selection on MCD
AUDIO FEATURES
MOSFET 50 Watts x 4 high power
Pop-up Rotary Volume control
EEQ+ (Easy Equalizer)
EQ-EX (augments EEQ)
3-Band Parametric Equalizer within EEQ
HPF/LPF Crossover within EEQ
Built-in Subwoofer Crossover (50/80/125Hz)
Direct Subwoofer Drive
Subwoofer Phase Selection (+/-)
Electronic Bass / Treble
SFEQ (Sound Focus Equalizer) - replaces FIE
Selectable Loudness Control
Electronic Volume / Balance / Fader controls
3 prs RCA Preouts (F + R + Subwoofer)
4-Volt RCA Preout Levels
SLA (Source Level Adjuster)
ASL (Auto Sound Levelizer)
Level Indicator
AUX IN capable via CD-RB20
Cellular Mute
ADDITIONAL FEATURES
OEL (Organic ElectroLuminescent) Display
128 x 33 Pixel Display
Card-type IR Remote Control
Flap-type DFS (Detachable Face Security)
DFS Hard Carry Case included
Detachable Face Reminder Beep
Operation Beep Tone
Source TV Control
External Unit Control
DVD Control
Adjustable Brightness Control
Clock
System / auto antenna relay control
Front or rear mounting options
Toyota/Nissan factory mounting holes
