Results 1 to 10 of 3070
January 18th, 2016 02:20 PM #1
Do you have an external amp or it would be powered by the HU alone? If so, a advisable set of budget speakers that would be powered by the Head Unit alone is the Infinity Reference Series speakers. It's a low wattage, high sensitivity, 2ohm set of speakers. Very ideal to be driven with the HU's limited power.
Mas malakas po siya tutunog compared sa previous speakers ninyo and halos same lang ang SRP nilang dalawa.
- Aug 2014
- 73
January 19th, 2016 02:44 AM #2
- Aug 2014
- 73
January 19th, 2016 02:48 AM #3pa follow up lang sa question ko.. ok lang b ang nakamichi na brand ng speakers? pamalit lang naman sa stock hindi naman pang bayo? salamat sa sasago chaka mga magkanu kaya yun para sa front and sa rear ko para sa vios salamat uli follow up lng po
January 20th, 2016 01:11 PM #4
- Oct 2009
- 348
January 20th, 2016 03:25 PM #5
January 21st, 2016 12:32 PM #6
- Oct 2009
- 348
January 21st, 2016 01:44 PM #7
sira na daw according sa electrician. both lower half of front speakers were badly corroded. the rust ate through the bottom half of the speakers where the the bottom half of the cone has become detached from the metal frame. i have no idea how much speakers are as i have never needed to replace any from our previous cars. how much would speakers like the one that the car came with would cost these days?
January 22nd, 2016 01:20 PM #8
Mukha nga kaiangan nang ma replace iyan luma. While you're at it with the electrician might as well check the other gears that needs replacement or repair as well. Those old ES series components you have cost around 3,800-4k bnew.
Where are you from? Maybe we could recommend a reliable car audio installer near your area so you can check the prices and relay your queries.
To have an idea re. speaker prices visit the mickey's autosound website.
- Oct 2009
- 348
January 22nd, 2016 10:18 PM #9
January 24th, 2016 11:13 PM #10
Sirs I just bought an AVT underseat slim sub, had it installed by a local auto shop. It sounded good naman po. Lately i think i need to adjust/tune the subwoofer for better sound quality but i do not have any idea how to adjust its phase and frequency and the HUD settings like the high and low pass filter. Meron ba dito parang template nalang to follow your figures/settings, i am
After sound quality lang po..(isuzu mux ls-a and the head unit they told us -avt din po. Thanks in advance..
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
