Page 70 of 154 FirstFirst ... 206066676869707172737480120 ... LastLast
Results 1,381 to 1,400 of 3070
    Feb 2011
    #1381
    any thoughts on sound magus c160 hifi may mga 2nd hand for 6k.
    Wala na nga lang ak9nv makitang manuals... :|
    Aug 2010
    #1382
    Quote Originally Posted by kazer View Post
    For 5k, you can always buy a brand-new Dominations amp. There are also some budget amplifier brands that might appeal to you.
    Mar 2012
    #1383
    yung v160 na 2ndhand sana bilhin ko dati and 5k+ lang yung price which is the newer version of the c160. May mga nag advice sa akin sa KAC that at that price range, you can also buy a branded 2nd hand amp like JBL. I got a Rockford fosgate P3002 at 6k sa KAC. Tyaga lang sa pag check sa ICE section.
    Feb 2011
    #1384
    A couple of thousand bucks more, you can get a brand new Audio System/Gladen Amp. Sound Magus tend to have high ratings because it does not use the CEA standard for measuring power, and as far as I remember it does not take into consideration +N(Noise) on it's measurements. In effect, baka pareho lang ang makukuha mong power buying another amp recommended here, baka lamang pa nga yung iba, tapos brand new pa sila.
    Jan 2014
    #1385
    Mga sir, hihingi sana ako ng tulong. Wala kasi akong idea kung ano dapat kong gawin. Gusto ko sana bumili ng subwoofer for my GM6. VX+ sya kaya may tweeters and speakers na. Gusto ko lang sana madagdagan ng bass yung tunog. What should I do? Sorry po sa sobrang newbie ko. Salamat in Advance. Budget po is 6-8K. Thank you.
    Feb 2011
    #1386
    Quote Originally Posted by Par_Alas View Post
    You can try looking at KotseAudioClub and check the selling section for a sub, enclosure and amp. But you might get 2nd hand items for that budget, why not increase it a bit and get brand new to match your new car?
    Jun 2014
    #1387
    Any flux amplifier users here can you share your thoughts on the amp
    Aug 2010
    #1388
    (Reposting my post sa KAC)
    Flux isn't really known for their amplifiers since they started out with speakers. Seeing their website gives me two things I want to note. One is that the amplifier design is kinda ugly (no offense) and seems quite generic. If this is budget-priced, that would be acceptable naman. For the power delivery, seems normal naman. I don't like it when firms do not state with voltage they use so a fairer estimate would be power being around 70Wx4 at 4ohms.
    I don't really think you'll notice much changes in amplifier selection. Speaker selection affects your overall listening profile by a huge huge margin.
    Feb 2011
    #1389
    sabi nila mickeys, flux is a clean neutral sounding amp. they also highly recommend these vs other brands they carry around the same price. i haven't auditioned one, but i like their seps. ;)
    Dec 2014
    #1390
    Good Day Chaps, I need your inputs on my setup. I am after imaging and soundstage. Car is a focus hatch. Being the only passenger/driver, I have grown tired of the bland stock audio setup. I am currently looking into the following components: 80prs (acquired), 10tw3 (acquired), ps 165 fx (still looking for a good price), then front door deadening (inner and outer walls).
    Given that I would not be upgrading my battery/alternator, which amp would suffice my need? Do I need one? Can I use a pdx-v9 on my stock battery/alternator and not run into any problems if I am not an outrageously loud listener? Thanks to anyone who can chip in. :thankyou: Happy listening. Cheers!
    Feb 2011
    #1391
    Quote Originally Posted by hypnos View Post
    Nice selection of gears! I'm using the 165fx, and the price is pretty much standard among all car audio shops. Some though charge for the installation, but some like my car audio installer Simple Sound will install it for free when you get the set from him. Since you have an HU that should be full-active capable, take advantage of it and use a 4ch amp(seps) and a mono amp(subs). Then use the time alignment feature of the HU to remove localization and improve the soundstage.
    These new flax focals sound really different from the past. It now runs on the neutral to warm side. It also has a more pronounced midbass, even better than my previous K2Ps. Your stock alternator should also be fine since you won't really use power hungry subs.
    Dec 2014
    #1392
    Quote Originally Posted by sientobente View Post
    Thanks for the immediate response mate. I really appreciate it. Yep the performance of 165 fx is really otherwordly at its price. Any particular amp that you could point me to? Im not really looking for anything fancy, anything not power hungry, compact and would do the job. I am thinking of placing it under the driver seat. Is there such an amp that could drive both the seps and sub?
    Feb 2011
    #1393
    Try to look for a 5-channel Class D amp. It should be more compact than it's class AB counterparts and is more efficient. The Phoenix Gold SD800.5 is one of them.
    Aug 2010
    #1394
    Do you need an amplifier?
    Yes. While you can power your front components with the head unit, you can't with your subwoofer.
    Yes. In fact, I highly recommend the Alpine PDX-V9 over any other amplifier locally at its price region. It's pricey locally so it would be best if you can parallel import one. If you want something better, the JL HD900/5 is expensive but it's an end-all amplifier. I actually wouldn't mind swapping amplifiers if I see one used and in need of a swap.
    *Focal FX
    It isn't really otherworldly. It's just good engineering which is why you pay for Focal. But for the price, there's actually a lot of others who is better on paper-specifications. The midbass isn't strong, it's just the highs are tamed thus the midbass is perceived as better
    Dec 2014
    #1395
    Thanks sientobente. I will look for SD800.5's specs.
    jhnkvn the HD900/5's specs seems better but its a bit out of my budget. Perhaps if there is a cheaper alternative for the 2-way seps, the savings could offset for the amp's cost.
    Neverthess, your recommendations are highly considered. Thanks again.
    Aug 2010
    #1396
    PG's SD line of amplifiers is a hit and miss before due to noise issues. While they have rectified this problem it's best to still have a warranty when going for those.
    Feb 2011
    #1397
    Sayang, didn't know PG amps have those issues. Looks good though for the price.
    Regarding the Focal 165FX, here is a comparison vs the K2P
    165FX
    Sent from my GT-N7100 using Tsikot Car Forums mobile app
    Feb 2011
    #1398
    Sorry, it was difficult to post a message with attachments using a cellphone. so regarding these 2 graphs, it is a comparison between the k2p(first graph) and the 165KR(2nd graph). We can see that there is a midbass hump on the 165KR which gives it an impression that it has a strong midbass, but looking at the tweeter performance, it drops off around 3-4khz which makes it tamer than the older focal speakers, but it extends up to 20khz which is wider than the k2p. This gives out a warmer sound with a sense of airiness.
    The advantage though on the K2P is it is more hifi on it's measurements, seeing that it is more flat than the 165FX. To a listener, this may sound a bit more forward and leaner with the graph showing that it is more pronounced 1khz up.
    Dec 2014
    #1399
    Would 165fx give more soundstage compared to a scandinavia 1 + HV 165?
    Aug 2010
    #1400
    Actually, kung based sa graphs, I'll jump to the KR na. A flat response is most optimal because there's less "errors". You can always boost the midbass if ever din naman.
    However, graphs tell just one side of the story. In those testing, usually soundproof anachoic chambers yan. But throw the speakers to a car and it gets an entirely different response naman.
    Oh, and if you have a Scan + HV165, use those. In most 2-way applications, it isn't the midbass that's playing "catching up" but rather the tweeter. Having a large-format tweeter has a lot of advantages compared to small domed ones typical of car audio.
audio set-up for beginners [continued]
